turbonetics t3/t04b 54trim .48 a/r on a gsr
recently i just picked up this turbonetic t3/t04b .48 a/r 7 blade on the compressor . im not sure on the trim. i think its a 50 or 54trim. i thought i was getting a t04e 50trim turbo but the guy i got it from listed it wrong and got this instead...
so i was wondering if im able to get 300-350whp with this turbo on a forge internal gsr. im just going for low to mid range power. i dont plan on doing any 5th gear top speed pulls or anything. just wanted something with quick spool with good low to midrange power.
i believe t his is the compressor map for the turbo
it's neither a 50 or 54 trim, it is what you put the map up of though which is a vtrim. if you had the .63 exhaust housing it will do 300-350whp but the .48 is just too small for a gsr. on all the dynos i've seen, and there aren't many, the .48 housing is falling by 7000 on a gsr. if you swapped housings you would be set.
i use to have a vtrim myself and sold it for a real 50 trim, biggest problem with the vtrim is surge once the compressor hits a certain point. somewhere between 350-380whp is usually it from that turbo.
since you already have it, you could try it and go from there. worst case buy a .63 housing to bolt on. i'd probably start with a .7 bar spring and go from there.
would you happen to know where i could get a housing? but then it probably wont be cheap...
as long it makes good power(300 or more)from 2000-7000 rpm. i would be happy. i was planning to start out at 14.5psi but i guess i will go lower to 10psi like you said. i just wanted to make sure i had a stiff enough spring if it still made power in the 20psi range with a mbc
These are hard to get because there are few of those wheels available. Best to call turbonetics to get one. Tell them you have a v1/v2 8 bladed compressor wheel. It will sork for a GS-R until reversion hits at about 20psi.
tell them i have 8 bladed?
just want to make sure thats corrent since my is 7
i was looking at there web site. i think this is the housing i need?
http://turboneticsinc.com/store/inde...product_id=420
what you have is a good turbo for a d16, sell it to one of those guys and buy a 5431e billet
last i check a sc34 was 850 new. that was the turbo i was going for.
if this .48 a/r housing gets me near 300hp. i will be happy and be done with it. i will call turbnetics tomorrow
thanks for the help, both of you guys!
that was a while ago. they're going for about 600 new now because they're trying to rid the line entirely. but there are alternatives that are still less than the 850 that work well too.
i was told by mtber a week ago that it was 850... if its really 525, i be so ****ing ****. i would of gotten that turbo over this pos scammed *** turbo
sale must be over, they were 539 awhile ago, 579 now or 655 for the 5431e
the 3431e is what's commonly called the sc34 or their 57 trim
i just think you're going to kick yourself with that.48 housing, it's going to funkify your top end
if you could ebay your turbo for 300-350 you would be set to order a new precision
InTraining124
Jan 30, 2009 01:05 PM
rice is nice
Mar 24, 2006 01:27 PM
