d16a6 w/ about 15psi...what needs to be done?
Old Jun 6, 2002 | 12:24 PM
pbomers's Avatar
Default d16a6 w/ about 15psi...what needs to be done?
can somebody give me a list of things to do to run about 15 psi on my d16a6. should i be running around 9.0:1 comp? what all should i upgrade? pistons...rods...what?
if you could give me a complete list i would appreciate it. thanks!!!! Paul
Old Jun 6, 2002 | 12:27 PM
CovertFI's Avatar
Default Re: d16a6 w/ about 15psi...what needs to be done? (TinyCRX)
i knew this was a newbi question as soon as i saw the topic. first start with money when you have enough, do a search for sohc!!
Old Jun 6, 2002 | 12:56 PM
pbomers's Avatar
Default Re: d16a6 w/ about 15psi...what needs to be done? (CovertFI)
new name...smart question...not newbi. i have searched...and read....and have built 2 engines. d16z6 and b16a1. i was more interested in seeing peoples opinions on parts..what they like and don't like as wel as what people have had good luck with and what they hate. relax a little bit, it's more fun that way. anybody else have a decent answer?
Old Jun 6, 2002 | 01:52 PM
lelopez's Avatar
well, I plan on running 15-20 psi on my d16z6 ('90 hatch dx). I am building the block with endyn pistons (9:1), crower rods, iron sleeved block, str blockguard, ported and polished head, 450 cc injectors controlled by a hondata stage 2b, si tranny....etc.
I am using a garrett t3 turbo in a custom turbo kit with a starion fmic......
I should be done by the end of summer......hopefully sooner
Old Jun 6, 2002 | 02:13 PM
sushibug's Avatar
Default Re: d16a6 w/ about 15psi...what needs to be done? (lelopez)
if you are getting it sleeved why do you need a blockguard? bad idea imho
Old Jun 6, 2002 | 02:18 PM
dustin's Avatar
15-20psi on 450cc injectors eh? hehe
Old Jun 6, 2002 | 02:54 PM
Turbo Laser's Avatar
Default Re: d16a6 w/ about 15psi...what needs to be done? (dustin)
450's should be able to support 15 psi. With ideal situations they are good for a little more than 300hp on a 2.0 4G63 motor. I have some fancy formulas laying around but I can't find them. A D16A6 can take 15 psi with the B series rods and supra piston solution. That's what nathansboostedcivic is/was running on his D16. How much cash are you looking to spend and what engine management are you going to use?
Old Jun 6, 2002 | 03:01 PM
Default Re: d16a6 w/ about 15psi...what needs to be done? (NOCARLOSER)
Look into ENDYN's (www.theoldone.com) block posting. That's what ABAZ's using on his built ZC...and it's only like $300-400. I would definently like into that.
Old Jun 6, 2002 | 05:33 PM
pbomers's Avatar
ZDYNE ECU is what i was going to use. i haven't decided on how much money to spend yet. this is a winter project so i've got time and money to do this right. someone is really running 15psi+ with only pistons and rods though? got some good fuel management! that block posting is really cool to, i was thinking about that.
Old Jun 6, 2002 | 11:40 PM
Smashback's Avatar
Yeah with all the old timers like you mister member for 73 days we should just delete his post.
With proper tuning you should be fine with rods and pistons, blockguard for added comfort. Of course, when something goes wrong, get ready for sleeving.
Old Jun 6, 2002 | 11:42 PM
Smashback's Avatar
Isn't that what Jinxproof is running? Like 350 hp or something fairly crazy on 450cc squirters? Thought I saw him talking about that a ways back..
Old Jun 7, 2002 | 07:26 PM
Default Re: d16a6 w/ about 15psi...what needs to be done? (blackomega)
Check out http://www.homemadeturbo.com for more helpful hints...good luck
Old Jun 8, 2002 | 12:27 AM
Trac226's Avatar
Buy an extra d16.
Elitesky
12
Aug 5, 2010 10:48 AM
Homotor
Dec 4, 2009 12:04 AM
Boostfed86
Sep 12, 2008 10:47 AM
yellowturbo
Feb 28, 2003 05:16 PM
hondacivic4g
Feb 2, 2003 09:40 PM
