turbo help
Old Jun 7, 2002 | 11:00 PM
CalvitoSol's Avatar
Default turbo help
i'm wondering if a 3in downpipe will fit ok w/o any clearance issues on a turbo'ed b16a on a delsol. any have similar set-up? thanx
Old Jun 7, 2002 | 11:03 PM
bigTom's Avatar
Default Re: turbo help (theory48)
do u want to run a/c?
Old Jun 7, 2002 | 11:11 PM
CalvitoSol's Avatar
Default Re: turbo help (ek9t)
yes, i want to keep everything intact w/o having to remove or heavily modify/reloacte nething.
Old Jun 7, 2002 | 11:33 PM
inspyral's Avatar
good luck.
It seems like 2.5" dp's barely fit with A/C, so I don't see how you're going to fit a 3" dp down there. Maybe if you turned the turbo around so the turbine is on the passenger side, then you might have enough room for a 3" dp, but then I don't think you'll be able to get a filter on the inlet. Or, you could go from 2.5" at the turbine to 3" after it clears the A/C unit.
Old Jun 7, 2002 | 11:39 PM
CalvitoSol's Avatar
Default Re: turbo help (inspyral)
will a 2.5 inch piping be enuff for my car or too restricting? my plans are t3/t40e, drag manifold, ic, larger injectors. thanx
Old Jun 7, 2002 | 11:49 PM
inspyral's Avatar
3" would be ideal, but I don't see how you're going to fit it in there unless you ditch the A/C. 2.5" flaring to 3" after the A/C is a compromise.
Old Jun 8, 2002 | 12:13 AM
CalvitoSol's Avatar
well, i guess i have to go w/ the 2.5 in. those were my original plans but everyone was saying "3 in this, 3 in that" but oh well, comfort over a few more hp? i'll take the comfort especially in this hot @ss soCal weather. BTW, nice car inspyral, think i've seen some of you post around the forum. i noticed you listing the inline bosch pump on your site. can i get just anykind of Bosch inline or any suggestions? how bout the fuel pressure gauge? can you get it to work w/ the pump? thanx
Old Jun 8, 2002 | 12:36 AM
inspyral's Avatar
I'm not even sure it's a Bosch, but I did get a gauge to work after the pump. I used a Summit Racing gauge and fitting spliced into the fuel line going from the pump to my rail.
EdSales
Dec 27, 2009 10:15 AM
Ben Ogle
Jan 29, 2007 06:03 PM
downsouth0
Nov 29, 2006 06:39 PM
nickromeo
Apr 14, 2006 11:20 AM
EJ8 GSR-T
Dec 24, 2005 04:17 PM
