Anybody Running Boost on a D16Z6 with 76.6mm? GE sleeved! Need advise soon!
Just a quick question for a possible future build. Recently started my D16Z6 build. Will start as a built bottum end on my newly purchased GT3076R until i get my oversized valves, springs, retainers and etc in a new head. I have recently run across a local guy with a Golden Eagle sleeved Z6. My concern with this block is that its been bored previously to 76.5mm. I plan to drive this motor on a regular basis and ofcourse see a lot of track time. Is there anyone here on a bore this big thats running a good amount of boost(ie-25+psi)? Anybody have any opinions on this? Any info is good info!
thats pretty big, I'm boostin my z6 75.5 stock sleeve at 15psi wit t3/t4. i'd be inclined to say you would be ok, but how much extra are custom pistons? do u already have a block, if so I would just sleeve it if ur wantin sleeves then bore to ur likening.
Re: (Boostfed86)
If it's sleeved the only problem you're going to run into is getting a headgasket that's big enough. Other than that, you're fine.
Re: (Boostfed86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed86 »</TD></TR><TR><TD CLASS="quote">Does anyone make one that big? </TD></TR></TABLE>
Yes, but it would be one off, any of the aftermarket headgasket makers should be able to get you one.
You will also need a custom sized set of pistons like mentioned before, which again just about anyone will do but you're going to have to spend a little extra.
There's a few guys running around with 78mm bores, so it's all possible. If you can track them down I'm sure they could answer the one off questions a little better.
Elitesky
12
08-05-2010 10:48 AM
Mr.Kalinchuk
04-11-2010 05:15 PM
