Which turbo spools at about 3500rpm?
gt28RS with a equal length (although the log will help spool up quicker, the Equal length will give better top end). Tuned nicely with a 3" Down pipe and exhaust. But this is all speculating.
I had a t3/t04b s-trim w/stg1 .48ar making boost by 3k, and 11psi before 4k - on an old, stock d16. That turbine might be a bit restrictive for 8200 rpms though... If you don't mind tossing money at it, the GT28RS can get you 300whp along with a FAST spool. For a better spool and slightly less max whp [from the turbo], the GT28R would be perfect.
BTW shortie/elf manifolds tend to spool up even faster than logs, and flow better up top.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crowder13 »</TD></TR><TR><TD CLASS="quote">i do drive an sr20det which is an all around better motor w/o vtec</TD></TR></TABLE>
SR POWER! the 2871 is about the ultimate sr turbo, or the 3037s.
Marcus
Marcus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">GT3251E will spool about there and doesn't cost as much as a BB turbo</TD></TR></TABLE>
That's what I originally wanted to get...but they were backed up and were going to take about a year. If I had known I was going to get fucked around with my manifold, I would have waited for the GT32.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1158 »</TD></TR><TR><TD CLASS="quote">
That's what I originally wanted to get...but they were backed up and were going to take about a year. If I had known I was going to get fucked around with my manifold, I would have waited for the GT32.</TD></TR></TABLE>
I just got mine this week. You can now get them built and coated in less than 2 weeks. I got mine from STC (check sig). No numbers yet, but in theory (and in previous testing) the GT3255 spooled fully right around 3200rpm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crowder13 »</TD></TR><TR><TD CLASS="quote">my gt2871 makes full boost at around 3900 rpms at 13.5 lbs of boost</TD></TR></TABLE>
Nice spool up
Nice spool up
1996GsrVtec
Jul 7, 2002 07:42 AM
