how much hp and boost from a t3/to4e
Old May 31, 2005 | 02:38 PM
TheBobFather's Avatar
Default how much hp and boost from a t3/to4e
I have a garrett t3/t4- .48 ar- 60 trim non ball bearing. It will go on a built b16. Does anyone know the max boost or the hp this turbo will support? Anyone know of a place i can see a compressor map? Anyone have a set up with a similar turbo? I want to get to the 400-500 hp range so if you know a turbo that will better suit me let me know also. Of course i want it all.....................fast spool, high boost, no lag. All whoop ***!!!!!!!!!!!!! Trying to understand turbos and which ones are which is a little confusing so be gentle!!!!!!!
Old May 31, 2005 | 02:48 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: how much hp and boost from a t3/to4e (jnbhonda)
.48ar will die off in the top end with how much boost you'd need to run.
if it is a new garrett, they are efficient to 480hp at the crank.
get a .63a/r housing and youll be fine.
btw, turbo lag is part of owning a honda, get used to it. that turbo will start to spool around 4k and you wont see full boost until 4800 or so
Old May 31, 2005 | 02:54 PM
Default Re: how much hp and boost from a t3/to4e (wantboost)
What turbo then.....by the way i might decide to build a ls with my b16 head
Old May 31, 2005 | 03:00 PM
_entropy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jnbhonda &raquo;</TD></TR><TR><TD CLASS="quote">What turbo then.....by the way i might decide to build a ls with my b16 head</TD></TR></TABLE>
For 500 WHP you need to go bigger than that turbo, no two ways about it. Deal with the lag, you can't have a turbo that spools at 3K and makes 500 WHP on a honda sans nitrous, it don't happen.
Old May 31, 2005 | 03:06 PM
Default Re: how much hp and boost from a t3/to4e (Napoleon Dynamite)
didnt you listen to the last rhyme meathead
pay attention, your saying the same **** that he said
accord_raffi
Jun 23, 2009 10:25 AM
93first1
Apr 5, 2006 05:12 AM
onemoreday21
Nov 29, 2005 05:11 AM
Dramier
Jan 4, 2003 06:24 AM
