Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Earning my keep
Old Aug 31, 2010 | 07:31 PM
night's Avatar
Default Earning my keep
Edit.. oops. I looked at the wrong thread and thought it was locked. I reposted it into the FAQ. You can delete this thread.
I haven't searched around here because you have to know what you are searching for to search. So I just started reading.
And in my collecting for my own reference, I figure I could contribute to the sticky. Unorganized and still a work in progress, but...
longer studs https://honda-tech.com/forums/road-racing-autocross-time-attack-19/anyone-using-96-98-tl-studs-their-integra-0-375-longer-2813796/
wheel spacer https://honda-tech.com/forums/road-racing-autocross-time-attack-19/another-wheel-spacer-question-5mm-hub-wheel-centric-spacers-2811850/
master cylinders https://honda-tech.com/forums/road-racing-autocross-time-attack-19/brake-master-2809801/
cheap light wheels https://honda-tech.com/forums/road-racing-autocross-time-attack-19/cheap-light-track-wheels-2808898/
sunroof plug https://honda-tech.com/forums/road-racing-autocross-time-attack-19/getting-rid-sunroof-2793044/
koni's https://honda-tech.com/forums/road-racing-autocross-time-attack-19/few-koni-3011-3012-questions-2757027/
autopower rollcage https://honda-tech.com/forums/road-racing-autocross-time-attack-19/autopower-roll-bar-car-sunroof-2734602/
alignment https://honda-tech.com/forums/road-racing-autocross-time-attack-19/string-alignment-2685249/
brake bedding https://honda-tech.com/forums/road-racing-autocross-time-attack-19/video-how-bed-brake-pads-rotors-2693244/
composites https://honda-tech.com/forums/road-racing-autocross-time-attack-19/composites-ultimate-guide-2530175/
electric p/s https://honda-tech.com/forums/road-racing-autocross-time-attack-19/special-projects-electro-power-steer-2222562/
external powered mic https://honda-tech.com/forums/road-racing-autocross-time-attack-19/aiptek-action-hd-diy-powered-external-mic-2630627/
dual masters https://honda-tech.com/forums/road-racing-autocross-time-attack-19/dual-masters-anyone-2630591/
DIY shock velocity logging https://honda-tech.com/forums/road-racing-autocross-time-attack-19/diy-shock-velocity-datalogging-2453043/
Macstrut talk https://honda-tech.com/forums/road-racing-autocross-time-attack-19/building-race-car-rsx-vs-civic-si-2621516/
Battery relocation https://honda-tech.com/forums/road-racing-autocross-time-attack-19/eg-hatch-battery-relocation-2625665/
Ride height https://honda-tech.com/forums/road-racing-autocross-time-attack-19/ride-height-eg-2624422/
LSD https://honda-tech.com/forums/road-racing-autocross-time-attack-19/got-lsd-2620057/
F/R track https://honda-tech.com/forums/road-racing-autocross-time-attack-19/front-rear-track-difference-2746097/
Cusco/cheap roll bars/cages https://honda-tech.com/forums/road-racing-autocross-time-attack-19/cusco-roll-cage-1788507/
Helmets https://honda-tech.com/forums/road-racing-autocross-time-attack-19/helmet-fitment-problem-whats-your-experience-brands-2604318/
Prop valve/bias https://honda-tech.com/forums/road-racing-autocross-time-attack-19/proportioning-valve-brake-bias-question-1000th-time-1773310/
Suspension travel https://honda-tech.com/forums/road-racing-autocross-time-attack-19/question-about-suspension-travel-how-much-2598764/
Poly bushings https://honda-tech.com/forums/road-racing-autocross-time-attack-19/my-experiences-poly-bushings-info-post-1563815/
Tire width https://honda-tech.com/forums/road-racing-autocross-time-attack-19/tire-width-2593783/
Damper talk https://honda-tech.com/forums/road-racing-autocross-time-attack-19/problem-pic-suspension-2592022/
Battery cut https://honda-tech.com/forums/road-racing-autocross-time-attack-19/battery-cut-off-2592750/ / https://honda-tech.com/forums/road-racing-autocross-time-attack-19/kill-switch-how-where-yours-setup-2827705/
Corner balancing https://honda-tech.com/forums/road-racing-autocross-time-attack-19/corner-balancing-stuff-2547127/
Rake https://honda-tech.com/forums/road-racing-autocross-time-attack-19/%22rake%22-car-important-2365405/ / https://honda-tech.com/forums/road-racing-autocross-time-attack-19/theory-height-rake-race-car-need-input-2376541/
Camber https://honda-tech.com/forums/road-racing-autocross-time-attack-19/newbie-q-how-much-camber-good-2532333/
Steering quickener https://honda-tech.com/forums/road-racing-autocross-time-attack-19/steering-quickener-2530083/
roll cage info https://honda-tech.com/forums/road-racing-autocross-time-attack-19/roll-cage-qs-2714773/
Spherical bearings https://honda-tech.com/forums/road-racing-autocross-time-attack-19/faq-where-buy-spherical-bearings-other-misc-suspension-goodies-1510236/
Shot peen/Cryo treat gears https://honda-tech.com/forums/road-racing-autocross-time-attack-19/shotpeening-cryo-treating-gears-1349736/
Front/Rear stiffness https://honda-tech.com/forums/road-racing-autocross-time-attack-19/rear-stiff-front-stiff-there-right-answer-2647720/
DIY aero articles https://honda-tech.com/forums/road-racing-autocross-time-attack-19/few-diy-aero-articles-2642267/
Shock dynos https://honda-tech.com/forums/suspension-brakes-54/%5Bfaq%5D-shock-dynos-1104049/
starting point https://honda-tech.com/forums/showth...2632499&page=2
Shock bible http://farnorthracing.com/autocross_secrets6.html
poly bushings https://honda-tech.com/forums/road-racing-autocross-time-attack-19/polyurethane-bushings-2468419/
suspension geometry calc http://www.racingaspirations.com/?p=286
"Making it Stick" article , ,http://www.modified.com/tech/0508_sc...t_3/index.html
Proposal https://honda-tech.com/forums/road-racing-autocross-time-attack-19/question-how-put-proposal-together-2544137/
Getting started https://honda-tech.com/forums/road-racing-autocross-time-attack-19/how-get-started-driving-road-course-tracks-2530247/
and a great quote I found to cap it
- When we rally, going all out (as fast as we can go) is called 10/10. If we almost roll, we were going 11/10. If we roll, we were going 12/10. If we find ourselves upside down in a river with the car filling with water, we were going 13/10. When we just want to finish and the car is about to fall apart, we go 8/10.
Khevin
Dec 27, 2010 10:13 AM
SLOENUF
Sep 27, 2006 08:38 PM
kay_animation
Dec 23, 2004 06:02 PM
KiddEng
Audio / Security / Video
Sep 21, 2004 02:19 PM
HH814
Jul 11, 2003 11:57 AM
