ls/vtec question
Old 11-12-2004, 12:49 PM
KrispyKreme's Avatar
Default ls/vtec question
what ecu should i use for my ls/vtec?and also what are the advantages/disadvantages of b20vtec vs ls/vtec?
Old 11-12-2004, 01:11 PM
biggs2.3's Avatar
Default Re: ls/vtec question (lshatch318)
external oil lines. non vtec bottom end. those are just two of the cons for an ls/vtec. and you want to use the ecu for what ever motor the head came off of.
Old 11-12-2004, 07:19 PM
prada_2o0o's Avatar
lsvtec will put out more torque. i use a p28 with hondata.... very fun car, excellent for daily driving, just make sure you search and make sure you get the right components or else you could have a lot of problems.
Old 11-12-2004, 08:07 PM
saleensolution's Avatar
Default Re: ls/vtec question (biggs2.2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biggs2.2 &raquo;</TD></TR><TR><TD CLASS="quote"> and you want to use the ecu for what ever motor the head came off of.</TD></TR></TABLE>
why does that matter?
Old 11-12-2004, 09:10 PM
Default Re: ls/vtec question (prada_2o0o)
would a p28 be ok for now not chipped or anything b/c it will be a minute before i get hondata, if not then which ecu would be best until hondata
Old 11-12-2004, 09:35 PM
Combustion Contraption's Avatar
depending on how high/low your compression is, that would determine whether a stock p28 would be ok for the time being.
Old 11-13-2004, 01:43 AM
jarel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prada_2o0o &raquo;</TD></TR><TR><TD CLASS="quote">lsvtec will put out more torque..</TD></TR></TABLE>
a 1.8 ls/vtec will put out more torque then a 2.0 b20/vtec??
Old 11-13-2004, 06:56 PM
prada_2o0o's Avatar
Default Re: ls/vtec question (jarelee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jarelee &raquo;</TD></TR><TR><TD CLASS="quote">
a 1.8 ls/vtec will put out more torque then a 2.0 b20/vtec??</TD></TR></TABLE>
sorry not more than a b20/vtec... i meant more compared to an itr /gsr/b18c r .. etc..... i find my lsvtec alot more fun then my old c5
dellydavid212
05-03-2011 01:37 PM
BoostdRex
10-30-2005 10:11 PM
HksHaitian
09-10-2005 08:44 AM
Mr.DC2TurBo
09-15-2004 12:46 PM
12Civicls
04-28-2004 12:26 PM
Quick Reply: ls/vtec question
