ls/vtec, vtec not working help
hey guys i had a b16 and just did a ls/vtec but it seems like there is no vtec. any ideas on what could be wrong. I bought the G.E kit w/ dowells and head gasket. i tapped the head and routed the line to it. i dont know whats wrong. help
Re: ls/vtec, vtec not working help (bigislandc2)
do u have a chipped ecu or ne thing that will change vtec crossover. i have had the same problem w/ my lsvtec had crossover set at 5k and didnt think vtec was working hooked it up manually and had it come in later then u could really tell the diff. if not chk vtec solenoid screen and oil level/oil change
Re: ls/vtec, vtec not working help (lsvtec_hatchback)
u sure you have all the neccesary dowels and oil jets in the head and block. looks like you not getting oil pressure. how low is the oil. put a oil pressure gauge to the motor and check where the pressure is at
ok, well im running a p30 chipped ecu vtec was working when i just had the b16 in it. i do have an oil gauge to it and there is about 70-80 psi oil pressure. oil level is good just alittle over the point will that harm the vtec. what do you think it is? ill try to hook it up manually to switch or something
i think for the vtec pressure switch i had the power and grond backwards. because i dont have the plug for the switch i just had two wires with female connectors to them. but any ways the + (pos) is on the side where you push down the connector and ground on the other. can someone confirm this
Jagolas
10
08-08-2004 02:33 PM
