h22 swap into in a 92-95 civic shifter question please help
Old Feb 16, 2003 | 05:36 PM
buck02's Avatar
Default h22 swap into in a 92-95 civic shifter question please help
can any one send me a pic of how they mounted the shifter in the 92-95 civics i know you have to cut a small jole but were can anyone giude me and which cover to use to cover the shifter with help please pics will help or web sights
Old Feb 16, 2003 | 06:26 PM
fastwanabe's Avatar
Default Re: h22 swap into in a 92-95 civic shifter question please help (h22civic2)
the stock cover will work just fine but it will be tight.
Old Feb 17, 2003 | 09:47 AM
buck02's Avatar
Default Re: h22 swap into in a 92-95 civic shifter question please help (fastwanabe)
does anyone have any pics of the shifter install and with the cover on it do you have to trim the shifter for the cover to fit please explain
Old Feb 17, 2003 | 01:22 PM
buck02's Avatar
anyone can help
Old Feb 17, 2003 | 07:31 PM
K20Ahondas's Avatar
to be exact, you have to trim the rim all the way around on a stock h22 shifter in order to put the cover on. I have done over 10 h22 civic swaps. Pretty easy to do.
Old Feb 17, 2003 | 08:00 PM
buck02's Avatar
Default Re: h22 swap into in a 92-95 civic shifter question please help (1FSTCAR)
so just cut the ring out and put the shifter into the hole and bolt down right and the cover will fit
has anyone found out how they install the shifter on the out side the car on the bottom and send pics please
Old Feb 18, 2003 | 02:50 PM
K20Ahondas's Avatar
the hole needs to be cut out almost like a big square.
Old Feb 18, 2003 | 03:03 PM
poison's Avatar
I took pictures today and am working on uploadin 'em. but I'm work right now. I will definitely upload them tonight for you.
Old Feb 18, 2003 | 04:03 PM
buck02's Avatar
Default Re: h22 swap into in a 92-95 civic shifter question please help (poison)
cool man i hope there good i appreciate it alot
Old Feb 18, 2003 | 04:20 PM
poison's Avatar
no prob. I will actually have some batteries to spare for the digital camera, so I can take more pictures if those do not answer your questions as well.
Old Feb 18, 2003 | 10:36 PM
ranta18's Avatar
i have the prelude shifter mounted in the place racing box and have not had any problems. the hole was easy to cut with a jig saw and works great. i don't know what other "problems" people have had with it.
Old Feb 18, 2003 | 10:38 PM
poison's Avatar
as promised:
HTH
Old Feb 19, 2003 | 09:11 AM
buck02's Avatar
Default Re: h22 swap into in a 92-95 civic shifter question please help (ranta18)
could you please show me the kit and pics of the shifter box and how does it work does place racing have a web sight showing it and installed how it works
Old Feb 19, 2003 | 04:34 PM
redlineh22a's Avatar
Im in the same situation. Where do you find the shift assembly at?
Old Feb 19, 2003 | 06:41 PM
mxpx035's Avatar
Default Re: h22 swap into in a 92-95 civic shifter question please help (redlineh22a)
i did almost the same thing that poison did but on the prelude shifter assembly where the 2 cables hook up i took a angle grinder and shaved down the top so i still have my cup holders and you can't even tell anyone ever messed with it
Old Feb 19, 2003 | 06:50 PM
buck02's Avatar
Default Re: h22 swap into in a 92-95 civic shifter question please help (mxpx035)
cool i dont know exactly what your saying were you cut though
and anyone got pics of the place racing mouting box and how it works
Old Feb 19, 2003 | 06:52 PM
poison's Avatar
came with the swap.
h22civicsedan
Jun 1, 2008 02:29 PM
NICEHATCH
Feb 6, 2005 05:11 AM
BIGBLOCKEK
Nov 13, 2004 01:16 AM
buck02
31
Feb 19, 2003 09:21 AM
sol-racer
Mar 6, 2002 01:07 PM
