h22 hybrid questions pics please
can any one send me a pic of how they mounted the shifter in the 92-95 civics i know you have to cut a small jole but were can anyone giude me and which cover to use to cover the shifter with help please pics will help or web sights
Location: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
Re: h22 hybrid questions pics please (poison)
looks crazy....but you got to do, what you got to do, to make things work....
whay is the hole so big and do you have any pic of it with the shifter cover over the shifter and how do you keep the weather out of the cap with that large hole
Re: h22 hybrid questions pics please (h22civic2)
I don't have pictures of the shifter cables mounted at this time, but I will most definitely get them ASAP. I do believe Newman and some others may have pictures.
As for the holes being big. I fed the cables thru easily, and the shifter assembly is mounted properly and have had zero shifting problems.
I also have the stock center console over the shifter assembly to hide everything.
I will get pictures asap, though.
[edit]
as for your question on why it's so big, is because I wanted the prelude shifter assembly flush and mounted flat on the chassis, and so I can obtain the OEM cover and be flush with the center (not sticking up or anything).
[/edit]
[Modified by poison, 8:05 PM 2/16/2003]
[edit]
[/edit]
Re: h22 hybrid questions pics please (dgonzals)
The face of a man who is never going to do an H22 swap into his civic. That **** is crazy, i didn't know you had to cut out basically that entire middle section. Well, good luck to you installing your H22
edit: wrong arrow
[Modified by b16a ferio, 9:58 PM 2/16/2003]
edit: wrong arrow
Re: h22 hybrid questions pics please (b16a ferio)
I'd bet you anything if I gave you a ride in it, you'd change the reaction
what aRE YAL USEING TO KEEP THE hole cover frome wheather and send pics of the shifter in the car and with the cover over if you have to trim the shifter show mw pleasr to make cover fit
Re: h22 hybrid questions pics please (egMee)
Here is a pic of shifter installed before I painted everything black..
And here are two more pics with stuff installed.
As you can see everything fits nicely even the optional audio console..
In Import Racer magazine in the Jan 2003 issue they had an article of an h22 swap into a 92-92 hb and when he did he shifter assemble, he bolted the shifter plate on the underside of the chassis, instead of inside the car. Why do you think he did that opposed to doing it the way everyone does it on here?
Re: h22 hybrid questions pics please (hot_EG)
try this site i found http://www.h22hybrid.20m.com/
he has some detailed information on his h22 swap into an eg hatch
Re: h22 hybrid questions pics please (ebp 99 si)
any know how to cut the hole so i can use my bseries motor too with out cutting to much i need the pics of the hole before you insatll the shifter
Re: h22 hybrid questions pics please (t0p_sh0tta)
i know the b series dont fit i know that i was saying when i want to put my b20 in when i want to so i can interchange but if it cant its cool i will get rid of the b20 to my friend he wants it but please send some good pics of the holes cut with out the shifter installed and whit the cover and what you have to cut to get the cover to fit
Re: h22 hybrid questions pics please (junglerunna02)
They were probably using the place racing kit with the shift box that bolts onto the bottom of the car.. Same thing just more expensive and sometimes notchy.
Re: h22 hybrid questions pics please (Jason kiDD)
any one have the sight to were the shifter is on the outside of the car how did it work any pics out there and ehat is needed done to do it
jdmdxturd had his shifter on the bottom of his chassis when he had his H swap.
you might want to contact him or search for what he has posted.
