Skunk 2 shifter problem
I grabbed my dual bend shifter out of my del sol and put it into my eg hatch. My problem is that the shifter is really hard to put into gear. It takes alot of effort to shift the gears why would this be? I had no problem in the Del, but now its a pain in the ***. Whats the deal?
Risky Business
Re: Skunk 2 shifter problem (MurdersV8s)
You probably tightened the bolt going through the shifter and the linkage too much. Loosen it up a bit and put anti-seize lube everywhere.
yea the bolt that holds the shifter to the shift linkage is too tight just loosen it up a bit it should work fine affter that u dont really need anti sieze
Re: Skunk 2 shifter problem (slowdaintegra)
now it seems like the base of the shifter is hitting my exhaust pipe. What the hell did I do? How do I fix that problem it's really freaking annoying.
Modified by MurdersV8s at 3:49 PM 9/19/2006
blackjdmEKcivic
02-25-2005 01:52 PM
STHPERFORMANCE
07-06-2003 07:28 PM
