i have a rattling problem with my shifter
When Im on the freeway staying in 4th,5th gear my shifter starts to rattle and gets annoying. i was wandering what is the solution to this annoying sound. Is it an internal problem with my transmission like a bearing or bushing or is it an external problem where something is loose? Please give me input please.
if it sounds like its coming form around the shifter area it prob. is not coming from the tranny and is somting loose or rattleing againtst the shifter, is it the stock shifter?
Re: i have a rattling problem with my shifter (blackjdmEKcivic)
jack the car up and get under it and tighten up the bolt that attaches the shifter to the shift linkage and your problems will go away. Just be sure not to tighten it up too much or it will be really hard to move.
Re: i have a rattling problem with my shifter (DirtySol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtySol »</TD></TR><TR><TD CLASS="quote">jack the car up and get under it and tighten up the bolt that attaches the shifter to the shift linkage and your problems will go away. Just be sure not to tighten it up too much or it will be really hard to move.</TD></TR></TABLE>
yeah it wil lbe very hard and tight to put it in gear.
Re: i have a rattling problem with my shifter (POE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POE »</TD></TR><TR><TD CLASS="quote">
yeah it wil lbe very hard and tight to put it in gear.</TD></TR></TABLE>
Did that one before, then I lowered the car to test it. Then had to jack it up again. Just make sure you check how tight it is before you drop it.
STHPERFORMANCE
07-06-2003 07:28 PM
