Short Shifter problem
Old Jan 6, 2007 | 04:28 PM
krazykay5487's Avatar
Default Short Shifter problem
I just installed a skunk 2 short shifter after i finished it was extremly hard to shift the gears, like i have to force it in the gears...is this normal? did i do something wrong?????please help thanks
Old Jan 6, 2007 | 05:21 PM
redGSRguy's Avatar
Default Re: Short Shifter problem (krazykay5487)
Try loosening the bolt that holds the linkage to the shifter.
Old Jan 6, 2007 | 05:26 PM
1badteg's Avatar
x2
Old Jan 6, 2007 | 08:18 PM
Default Re: Short Shifter problem (redGSRguy)
thanks ill try that i hope it work, should I lube it or anything>???
Old Jan 6, 2007 | 09:32 PM
Rhythmsnewsn's Avatar
never hurts to throw some grease on
Old Jan 7, 2007 | 03:50 AM
god.loves.ugly
Guest
Posts: n/a
you tightened it too tight like the first guy said.
and lube that **** up while you're at it.
christiantequila
Apr 13, 2008 09:51 AM
gameknb
Jun 11, 2005 07:32 AM
starbury
Feb 15, 2005 09:58 AM
STHPERFORMANCE
Jul 6, 2003 07:28 PM
SOHC_MShue
Jun 20, 2002 02:44 PM
