Long drain intervals and Oil Filter Question
Old Apr 21, 2004 | 09:14 AM
lowgman's Avatar
Default Long drain intervals and Oil Filter Question
I've been reading some stuff about extended drain intervals with synthetic oils, namely AMSOIL oil.
It claims that you can go without an oil change for 25,000 miles but recommends an oil filter change inbetween.
How the heck do you change the oil filter without changing the oil?!
From my experience, each time I pull off the oil filter, oil starts coming out. I would imagine on a full crankcase of oil, more would come out and also with that anti-drainback valve inside, some oil would still be at the top.
Old Apr 21, 2004 | 09:20 AM
BauleyCivic's Avatar
Risky Business
Default Re: Long drain intervals and Oil Filter Question (takoek9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by takoek9 &raquo;</TD></TR><TR><TD CLASS="quote">
I can't believe you actually asked this. The oil doesnt stay in the crankcase buddy, it drains down into the oil pan. The oil filter will always have oil in it when you pull it out, regardless of if you have a 4 qts of oil in the car or nothing in the car.
Old Apr 21, 2004 | 09:37 AM
Formula 1's Avatar
Default Re: Long drain intervals and Oil Filter Question (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">
I can't believe you actually asked this. The oil doesnt stay in the crankcase buddy, it drains down into the oil pan. The oil filter will always have oil in it when you pull it out, regardless of if you have a 4 qts of oil in the car or nothing in the car.</TD></TR></TABLE>
yes it drains down, let the car sit for a while then get a rag and put it under the filter as u pull it off then put the new one on quickly
Old Apr 21, 2004 | 10:29 AM
lowgman's Avatar
Not all the oil drains into the oil pan. The anti-drain back valve is *supposed* to keep some of the oil up there to help oil during a startup. Whether the anti-drain back valve works 100% or not is another question.
I'm also asking this question for other cars, especially the ones with the oil filters pointing down. and near the bottom of the block.
Old Apr 21, 2004 | 10:40 AM
monicle's Avatar
like this. all the oil will drain out. greddy oil filter relocation kit.
Old Apr 21, 2004 | 10:42 AM
B_CRUZ!'s Avatar
Default Re: Long drain intervals and Oil Filter Question (monicle)
TRD filter on your GS-R motor
Old Apr 21, 2004 | 11:04 AM
monicle's Avatar
Default Re: Long drain intervals and Oil Filter Question (b cruz)
yep heh and dsm injectors. Im all sorts of mixed up under the hood.
Old Apr 21, 2004 | 04:14 PM
Formula 1's Avatar
i want the filter relocation kit, i hate where the normal b series one is cuz oil drips on yur header when u pull it off
happynoodleboy
Feb 20, 2008 06:34 PM
J.nguyen
Oct 14, 2006 06:04 AM
Thasty
Honda Motorcycles
Sep 4, 2004 08:28 PM
Floyd
Sep 23, 2003 07:08 AM
daLixz25
Jan 5, 2003 06:10 PM
