How much oil is needed for an F3 oil change?
try doing a search first, it's been posted before, but here is a DIY for an F4, same thing i belive
http://www.bossturbo.com/cbr/howto_oilchange.shtml
3.4 quarts if you're changing just the oil. 3.7 quarts if you're also changing the filter. Don't forget to lube the o-ring of the oil filter with a little bit of oil before installing it.
And don't forget to put the drain plug back in before you pour in oil.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marmaladeboy »</TD></TR><TR><TD CLASS="quote">3.4 quarts if you're changing just the oil. 3.7 quarts if you're also changing the filter. Don't forget to lube the o-ring of the oil filter with a little bit of oil before installing it.
And don't forget to put the drain plug back in before you pour in oil.</TD></TR></TABLE>
haha, thanks marmalade... i just did 4 quarts. I miss this forum, sucks i dont have a bike anymore... damn i miss my 6
happynoodleboy
Feb 20, 2008 06:34 PM
lowgman
Apr 21, 2004 04:14 PM
Floyd
Sep 23, 2003 07:08 AM
dclub01
May 1, 2003 03:22 PM
