Help! VSS removal
Old 02-06-2008, 09:58 AM
buffaluphagus's Avatar
Default Help! VSS removal
I just changed out my clutch and I need to add trans fluid. My fill plug is completly striped and not coming off. I read that fluid can be added through the vehicle speed sensor. I have the three bolts off and its unpluged. I cannott seem to get the sensor out of the trans. Help would be greatly appreciated. I already broke off one of the bolt tabs from the sensor. I have a 95 dx couple 1.5 non vtech
Old 02-06-2008, 10:00 AM
JDM_SOHC's Avatar
Default Re: Help! VSS removal (buffaluphagus)
non VTEC u mean
an theres only one bolt that holds the VSS in, its the goofy lookin long 10mm bolt on the top left... once thats out u just need to put some elbow grease into it, but dont pull it out by the harness unless u have some spare pins laying around with a VSS diagram lol.. Just pull that bitch an it will come out... It helps to turn it left an right while pulling upwards...
Old 02-06-2008, 10:12 AM
JDM EJ2's Avatar
Get a small pick and pry on it easily, don't just start smashing it. Give it force and be gentle ya dig?
Old 02-06-2008, 10:49 AM
JDM_SOHC's Avatar
Default Re: Help! VSS removal (JDM EJ2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM EJ2 &raquo;</TD></TR><TR><TD CLASS="quote">Get a small pick and pry on it easily, don't just start smashing it. Give it force and be gentle ya dig?</TD></TR></TABLE>
u mean don't start smashing it until your 30 minutes into the job an its still not coming out.. than u smash anything available to be smashed an u say every swear word you've heard... than give it another shot after that, usually does the trick for me...
Old 02-06-2008, 10:51 AM
Datphan's Avatar
Default Re: Help! VSS removal (JDM_SOHC)
you could also fill it up at the breather tube, a slow process though.
Old 02-06-2008, 11:46 AM
got it thx
Old 02-06-2008, 12:01 PM
JDM_SOHC's Avatar
Default Re: (buffaluphagus)
did u try the whole wiggle left an right while pulling up thing??
Corksil
05-31-2008 12:03 AM
pazookie
05-06-2008 12:28 PM
EG_Civic_Si
02-13-2006 04:11 PM
Edwardo911
30
09-10-2004 01:43 PM
araknis
04-10-2002 03:38 PM
Quick Reply: Help! VSS removal
