99 B18b into a Civic HX
Well, my d16y5 (2000 civic HX) is fried. I am now going with a 99 b18b. I have a few questions as to what I need. I have done some research, but still need some help. Other than the engine and tranny, I would need a 99-00 si rear tranny mount, I will also need a Si driver side mount, a 96-97 del sol ac bracket. A shift linkage from the 99 integra. What about wiring, keep in mind that it doesnt need to be smog legal. Can I use my stock harness? Can I use a 99 integra ecu? What else has to be done. Thank you guys very much.
Re: 99 B18b into a Civic HX (imlachg1)
for the driver's side you can use your d series bracket.. it will fit.. the only thing is you need the pass. tranny mount from integra, and you need SI shift linkage instead .. you can use your stock engine harnesss.... the ecu i'm not positive.. I believe they're both OBD2b, you should be good to go.
esoterEK..
08-04-2003 07:20 AM
