Function and Form coilover thread
Old Nov 6, 2012 | 10:36 AM
  #1751
racerx510's Avatar
Default Re: Function and Form coilover thread
Originally Posted by theEGGmonsta
you can be ghetto and cut a hole through the shock tower
or to look nice you can weld a box over it
i actually like it open, but better if it was cleaned up, looks like it makes camber adjustments easier
Old Nov 6, 2012 | 05:14 PM
  #1752
just Touge's Avatar
http://www.flickr.com/photos/just_touge/8105637845/http://www.flickr.com/photos/just_touge/8105637845/ by http://www.flickr.com/people/just_touge/, on Flickr
Old Nov 7, 2012 | 04:50 AM
  #1753
dragva5g's Avatar
^those the real work cr01 or the replica?
Old Nov 8, 2012 | 10:40 AM
  #1754
Caddiman's Avatar
i believe they are real
Old Nov 8, 2012 | 03:48 PM
  #1755
blown_ss's Avatar
Type 1s. This is my 3rd set that I have owned. For the price you can't beat the ride.
Old Nov 9, 2012 | 05:59 AM
  #1756
SJ-CIVIC's Avatar
^^^^ 3rd set cause of failure or new cars?
Old Nov 9, 2012 | 02:46 PM
  #1757
blown_ss's Avatar
Because I can't keep a car! I wouldn't keep buying something if they failed on me. My brother has been driving on his type 1s for 3 years with no problems.
Old Nov 10, 2012 | 06:57 AM
  #1758
crazymikey's Avatar
Type 1's on CB7.
Running 205/40/17 tire. Front's were cranked down slightly lower than the rear. No camber adjustments in this pic. Later fitted an anchor bolt kit in the front, but caused the UCA to hit the inner fender. Did not want to be ghetto and cut out the strut tower, so I took the kit out and raised the front up a bit to reduce the rake.
Old Nov 14, 2012 | 09:43 AM
  #1759
ej6kid's Avatar
I have type 1's on my sedan, maxxed out. I want to lower the front a bit more. Any other way to get it lower besides messing witth the preload?
http://www.flickr.com/photos/sublime1304/8037092339/
Old Nov 14, 2012 | 09:56 AM
  #1760
SJ-CIVIC's Avatar
^^^^ Your 4 door looks bad ***!
I think the only way to get them lower is to do the OEM top hats I think someone posted that in a few pages back. BUT that will require resetting the pre load there's no other way.
Old Nov 14, 2012 | 10:12 AM
  #1761
Ricky07's Avatar
I adjusted the preloads down about an inch on my old integra and the ride quality was horrible. Find another way.
Old Nov 14, 2012 | 11:45 AM
  #1762
ej6kid's Avatar
Thanks man, it's on esm wheels now. Yeah i wasnt sure if that was jsut for the prelude or all models..And if i switch out tophats, i should mess with the locking collars where the preload is adjusted, no?
Old Nov 15, 2012 | 06:01 AM
  #1763
SJ-CIVIC's Avatar
My assumption is that if your going to remove the top hats to change out for the stock top hat set up Pre load is going to need to be taken off and tweaked BUT once you have the stock top hats on you can reset it but measuring where the spring collars are at now and reset once you switched everything.
I hope I made sense lol
Old Nov 15, 2012 | 09:08 AM
  #1764
Caddiman's Avatar
ej6kid, car looks great buddy those are 15's right?
heres mine with more room to play with
Old Nov 15, 2012 | 10:10 AM
  #1765
ej6kid's Avatar
@caddiman, I loveeee your 4door! Mine are maxxed out, it's a little lower now on my new wheels. But yeah, they are 15's. I am considering making drop forks instead of messing with the preload. These go plenty low, but I want lower -_-
Old Nov 15, 2012 | 10:31 AM
  #1766
Caddiman's Avatar
thanks bro....haha, do it man! It looks great already tho
Old Dec 1, 2012 | 08:51 PM
  #1767
jahong16's Avatar
fnf type I
do the type II or 2.5 come with camber plates? my hardrace camber kits are hitting the strut tower like the picture above and i do not want to cut a hole.
Old Dec 2, 2012 | 03:28 PM
  #1768
Chikken's Avatar
I'm on Function&Form Type 1s on my 7th gen V6 Accord Coupe
Old Dec 2, 2012 | 08:01 PM
  #1769
EFSedan#6's Avatar
It is a toss up between Skunk2 Pro S or Type 2's or D2 36 way's. Ugh. I am so undecided because my Omni Full Coilovers blew within 5-6 months on my Eg Sedan.
Old Dec 2, 2012 | 08:25 PM
  #1770
CLUTCH*1's Avatar
When it comes to Ride Quality and Lowest Setup without touching Preload F2 wins hands down.
Now add in Warranty experience from previous customers you will find that F2 has a Quick turn around time
Compared to other companies so you car is not on jacks for too long when there is a problem.
When you do your research and compare price with customer satisfaction you should have a clear decision.
My E36 on F2 Type2
Old Dec 3, 2012 | 02:43 PM
  #1771
thrasher324's Avatar
wow
Old Dec 4, 2012 | 07:19 PM
  #1772
gt58's Avatar
anyone on type 2.5's with 14/10 spring rates??
Old Dec 4, 2012 | 08:37 PM
  #1773
ej6kid's Avatar
All you dudes with type 1's who messed with preload, can you adjust the springs back to factory preload or once you touch it you're effed for good
Old Dec 4, 2012 | 11:32 PM
  #1774
CHiLD's Avatar
lol, of course you can preload the springs again.
Old Dec 4, 2012 | 11:35 PM
  #1775
CHiLD's Avatar
Originally Posted by jdmbb68o8
The secret is OEM top hats.
the 2 missing perches makes a difference
