Function and Form coilover thread
Old Mar 7, 2012 | 11:00 AM
  #1651
Caddiman's Avatar
Default Re: Function and Form coilover thread
im going to be cutting my shock towers soon. just gotta make time. my pops is a welder so hes gonna fab me up something
Old Mar 7, 2012 | 11:05 AM
  #1652
soclean's Avatar
I've never had problems in the past with hitting my uca. Is this the only suspension that has that problem?
Old Mar 7, 2012 | 12:13 PM
  #1653
killahsi2003's Avatar
FF Type 1's with over 20K miles love them!!!
Old Mar 7, 2012 | 02:27 PM
  #1654
SHG_Claudio's Avatar
That has NOTHING to do with the F&Fs..... If its hitting the UCA then its because you don't have enough shock travel which is caused by your ride height being too low or you hitting big bumps/dips. The lower you go, the stiffer you need to be to limit suspension movement so that it the UCA doesn't bottom out.
Old Mar 7, 2012 | 02:36 PM
  #1655
soclean's Avatar
Will the extended top hats fix that problem if I want to go low?
Old Mar 7, 2012 | 02:50 PM
  #1656
Functions and Forms don't have extended top hats and no that won't fix that problem. The problem is that your upper control arm has a physical barrier that it will hit after a given amount of movement. The lower you are, the closer it is to the tower. So to fix that problem you need to limit how much the UCA moves and if you stiffen up the springs it won't move as much. The other option is to simply raise your car a bit. Now you can also look into aftermarket control arms which might give you slightly better clearance but its very small. Most people run Skunk2 because they have tiny bolts so it helps but theres complaints about those little bolts slipping and thats just not good. Plus its Skunk2 so its iffy as is. Buddy club has a similar design that works well and I haven't heard of any issues from them. Thats what I would run personally. Something that slammed guys do is they cut the upper control tower and weld in new metal in a different shape in order to give it more room which helps but I mean how far are you willing to go?
You can see it here for example, he reworked the shape to appear OEMish too.
Its really all too simple, when you go low you either bottom out or you go stiffer, thats it! Accept it.
Old Mar 7, 2012 | 02:54 PM
  #1657
soclean's Avatar
Ok I appreciate all the info. I wasn't really trying to go as low as these other guys that tuck all tire. The height I wanted is exactly like the eg hatch on the previous page so hopefully I won't hit the uca at that height. If it does then I guess I have no choice but to modify it somehow.
Old Mar 9, 2012 | 10:08 AM
  #1658
93dxz6's Avatar
Ok I'm having a big issue here...I just got my function form type 1s,installed them but when I got done and put the car back on the ground it was uneven at every corner??only way I could get it somewhat level was to raise/lower each coilover to to match the other side...I did not mess with the preloads I just raised/lowered the very bottoms of them any ideas as to what the issue would be???any help would be great
Old Mar 9, 2012 | 11:41 AM
  #1659
furious94ls's Avatar
Thanks to this thread, I'll be avoiding these.
Old Mar 9, 2012 | 01:15 PM
  #1660
WhiteSlips's Avatar
That is going to be the case with every coil-over setup. Each corner of your car will weigh slightly different so to get all four corners perfectly even you have to play around with the adjustment to get it just right. I've had a full Omni setup, a Skunk 2 sleeve setup, and now a full Tanabe setup and all three of them required fine tuning of the ride height to get all four corners even.
Old Mar 10, 2012 | 10:27 AM
  #1661
soclean's Avatar
I finally got these installed and the ride is so smooth. Im not low to the ground but low enough and I love it. I did a lot of research before I purchased a set and I really think it is a hit or miss and really depends on who you buy it from. I am super happy with the ride and glad I chose to take the risk and buy them.
Old Mar 14, 2012 | 09:01 AM
  #1662
CLUTCH*1's Avatar
Icon7 Re: Function and Form coilover thread
Make Sure to Send in your Warranty Card
So they can have your Info on File just in case.
Old Mar 14, 2012 | 10:04 AM
  #1663
soclean's Avatar
Thanks for the heads up. I didn't even know I had to do that.. I will definitely get it out asap.
Old Mar 20, 2012 | 06:05 PM
  #1664
SWK_cb9's Avatar
Type 2s With a good lil ways left!! And Strut towers are cut.
Old Mar 22, 2012 | 08:01 PM
  #1665
Serge L's Avatar
Originally Posted by XJorXdanX
Have to say I love them, they might be the type ones, but I have no complaints, only bought them because of seeing this thread while looking for reviews on suspension
I've had megan's, cxracing, godspeed, and now function and form, and for a unadjustable dampening shock, they are amazing.
Uploaded with ImageShack.us
are those 15x8 +0 195/45/15 ??
Old Mar 22, 2012 | 10:32 PM
  #1666
Jdmhondaa's Avatar
yup^ look like 50s tho.
Old Mar 23, 2012 | 08:50 AM
  #1667
Serge L's Avatar
just ordered my type 1's yesterday cant wait to get them next week :D
Old Mar 23, 2012 | 11:02 AM
  #1668
soclean's Avatar
I have some rear extension forks for sale if anyone needs them. I bought them and decided not to use them anymore. They are brand new. Just pm me
Old Mar 26, 2012 | 07:52 AM
  #1669
SJ-CIVIC's Avatar
Has anyone come to find that the wrenches they give to loosen the locking collar are garbage. I tried to adjust my coil overs yesterday and the stupid wrench sucks and wouldn't grip the notches and kept slipping so I wrapped a rag around the collar with channel locks and loosened it with ease.
Old Mar 26, 2012 | 10:11 AM
  #1670
soclean's Avatar
^ yes they are garbage. I use a flat head and hammer to knock it loose and tighten them by hand.
Old Mar 27, 2012 | 03:41 PM
  #1671
tylerfromnj's Avatar
I need help. mine are maxed out and I wanna go even lower. I'm scared to mess with the preload though. how much more drop will I be able to get out of them? my ride is already very shitty due to how low I have them... so I'm not worried about that.
Old Mar 27, 2012 | 03:51 PM
  #1672
soclean's Avatar
What kinda of car do you have?
Old Mar 27, 2012 | 05:15 PM
  #1673
Jdmhondaa's Avatar
yur ride will be the same as long as u dnt mess with the preload, dropping it will give anuthr inch common sense....
Old Mar 27, 2012 | 05:16 PM
  #1674
Jdmhondaa's Avatar
wat rims on the accord up there?
Old Mar 27, 2012 | 06:36 PM
  #1675
EK. Do you have any experience with messing with the preload?
shut up. you do not know how to read.
