DA Integra's Only
Old Jul 11, 2015 | 06:59 PM
  #54201
Lord Helmet's Avatar
Default Re: DA Integra's Only
Originally Posted by 91b18a1ls
Thanks. Stock b16a (arp head studs, cometic head gasket), garrett 50 trim, 13lbs, on e85. That's about it
So after talking about getting a fire extinguisher for my car I finally got one =]
Found this automotive B & C grade one at Walmart for $15
I wanted to mount it close to the driver seat so if something happened it would be within easy reach. I ended up mounting it on the underside of the dash panel
I hope I NEVER have to use it, but it's a nice thing to have just in case something bad were to happen especially for just $15
Ahhh I see, I thought I heard the bov when you lifted lol Garret t3/t4 50 trim? Almost the same setup I'm going minus the head gasket, e85, and I have the b18c1 in my DA.
I drove my brother's DA B16 turboed. It's quite addicting to not smash the throttle
Old Jul 13, 2015 | 04:49 PM
  #54202
NewCarScent's Avatar
Very smart purchase, it's actually up next on my to-do list.
I always loved this car and the way it sounded when it was NA, but boost is very addicting.
Hope you're having fun with it on and off the street.
Old Jul 13, 2015 | 06:52 PM
  #54203
91b18a1ls's Avatar
Yep Garrett t3/t4 50. E85 is the way to go man. I've been on it since 2012 and don't plan to switch back...ever. Smells way too good lol
Definitely. Wish I did it years ago. I'd get one for my db1, but idc if that pos burns to the ground. That might actually improve it. Yeah I miss the rsr it had when it was n/a, but I love the turbo noise so it makes up for it. I have WAY too much fun with it trust me.
Noticed a small coolant leak while at cars and coffee on Sunday. Saw dried blue drops on my trans and then noticed the back side of the distributor was wet. Something is spraying coolant, but haven't had a chance to get the pressure test on it and check. No big deal though.
Shot of it from cars and coffee right before I noticed the leak
IMG_1627 by Mark Freeman, on Flickr
Old Jul 14, 2015 | 03:54 AM
  #54204
hb420's Avatar
Old Jul 14, 2015 | 03:36 PM
  #54205
Right on. I'm not too familiar with running E85. Did you have to swap the fuel lines to run them? I "heard" that E85 is corrosive. Your thoughts on E85? I thought about running methanol injection down the road though.
Old Jul 14, 2015 | 04:17 PM
  #54206
91b18a1ls's Avatar
LIES! All lies. I'm running stock tank, stock lines, stock rail, stock fpr, even stock fuel filter. Been running like that since 2012 and everything is flawless. I pulled the tank in 2013 to put the Walbro in after being on e85 for just over a year and half and it was shiny inside and looked brand new. When I pulled the rail last year to put the fid 1000's in it looked perfect as did the old injectors I pulled out. E85 will not harm your fuel system. Don't believe in the myth.
I love e85, love how cheap it is, love how it smells, love the power you can gain out of it with a proper tune. It's well worth it for a boosted setup if it's not your daily. I wouldn't want to daily it that's fore sure. Gas mileage will drop due to the increased amount required to make the same power as 93 (e85 requires roughly 30-40% more which is why you need a pump and bigger injectors). It's also not as easy to come by depending on where you live.
I don't know anything about meth injecting. Never messed with it
Old Jul 15, 2015 | 04:38 PM
  #54207
Ahh thanks for your input Yeah E85 is available at my local gas station. I'm not worried about fuel mileage since my DA isn't a daily driver anymore. I'll do more research about E85 and thanks again for the headsup
Old Aug 17, 2015 | 02:42 AM
  #54208
CaptivaBlueTeg's Avatar
A little dead in here. But here's my weekend.
B17 cable trans going in shortly
Old Aug 22, 2015 | 09:03 AM
  #54209
bhacek's Avatar
Hi guys, need help here...
i just bought integra DA5 93 and its still using ZC Carburettor,and its manual. i just wondering, can it be direct swap to B20 using b16 gearbox?and what kind swap mount kit from hondas? (purpose this build is for daily car but need more power,and upgrade breaks) Or i just buy ZC DOHC?
Btw, im from indonesia,jakarta. i bought this car so damn expensive.. $11.000+ belive it or not. with this mount of money i can buy bmw e90 2005.
still i bought this integra.. there's only 4 or 5 integra DA JDM series in my country ( as far as i know )
so, just need a bit of info,. maybe you guys been discuss it before, but i can't read all pages from 2004-now.. so guys.. a bit help here..
Thanks man..
Old Aug 22, 2015 | 08:10 PM
  #54210
818Digi's Avatar
Hi guys,
I just purchased a da9 Ls integra with 250k on original motor. Recently my check engine light came on and I jumped the code and the famous #6 is what the ecu throws. It comes and goes away for a few days....the car has no heating issues, so it's a bad ect sensor, Planning on changing the ect sensor soon because I need to pass smog in the next month.
This is the part I can't figure out.....some morning I start the car, it runs fine. Others, I start the car and it bogs down like its going to die, I press the pedal down w.o.t and it sounds like its backfiring or the engine can't breath or maybe no spark. I hold idle at 2k rpms for a few minutes, then let of the gas and it idles at 750rpm no problems. Wtf could it be? Bad map sensor? Bad dizzy? Both things are $300 dollars new and I don't wanna buy one if I don't. No other code is being thrown at this point.
Old Aug 23, 2015 | 07:24 AM
  #54211
bhacek's Avatar
Bump!!
Old Aug 27, 2015 | 12:36 AM
  #54212
springninja's Avatar
Thanks man..
Wow, you must seriously love DA Integras Haha! In NZ there are many DA Integras which are factory B16A and manual - I wonder if you can source an entire front cut from NZ? Have you got lots of B Series parts available in Indonesia?
Old Aug 27, 2015 | 01:31 AM
  #54213
bhacek's Avatar
its quite rare to have DA walking arround in my country.. B series parts not that much, usually we buy it on ebay or something.. curious, how much for front cut on DA and DB? if its worth it, i'll make a way to import from NZ, usually i buy part from malaysia.
Old Aug 30, 2015 | 02:39 PM
  #54214
As the cars are common in NZ, they are frequently on auction websites. Keep an eye out on Buy online and sell with NZ's #1 auction & classifieds site | Trade Me. Here's a complete tidy DA hatch with a B18A, but its a bit pricey to cut up and strip for parts. Honda integra 1992 | Trade Me
Unfortunately for you I got a DA8 Integra that I stripped and sold it for parts about 6 months ago - was a complete B16A manual car. Sold most bits to a local guy putting the engine in an EF.
I will keep an eye out for a car for you. If you're serious about getting the parts from NZ I can help sort things out at my end. You're probably best to PM me to save clogging this page lol.
Old Aug 31, 2015 | 06:05 AM
  #54215
bhacek's Avatar
Still looking a way from NZ ti IND.. sorry guys... yeah i will PM you after i got a way to import.. thanks And sorry talking trash here...
"Respect Your Elders" DA!
Old Aug 31, 2015 | 05:43 PM
  #54216
nyckid's Avatar
project molded lip/e36 foglights
and side skirts
Old Oct 4, 2015 | 10:21 AM
  #54217
hb420's Avatar
Bump
Old Oct 5, 2015 | 06:08 PM
  #54218
sr20paisa's Avatar
i have an ams 3 piece, exact one ron bergenholtz ran and tony fuchs had back in '95
Old Oct 15, 2015 | 11:54 AM
  #54219
joeyjh4da9's Avatar
Looking fwd to a good build its nice to see other fans of the sexy body style
Old Oct 15, 2015 | 03:11 PM
  #54220
Colin's Avatar
Originally Posted by Ef9vsDa9
Been seeing more and more popping up all over craigslist even Db2's,
95% of what I'm seeing are:
A) Beat to ****
B) Have all stock parts replaced with ebay parts that are worse than stock
C) Priced double what the car is worth
D) All of the above
DB2's are especially saddening, there are at least 3 for sale locally that are pretty much modded beyond the point of no return and the people think they're actually still worth something
Old Oct 15, 2015 | 10:59 PM
  #54221
joeyjh4da9's Avatar
I agree... I over paid for mine 2000.00 and I talked the guy down 500.00 however I plan on a very expensive elaborate build.... not top horsepower but top reliability attractive and fun to drive at 325 or 350hp why get more that's an affordable goal and it will be awesome to drive. its nice and I can customize it how I want. I love that about it the most I think...cheap to build compared to a v8 that's for sure...
Old Oct 16, 2015 | 07:10 PM
  #54222
stealthbeam's Avatar
Hey Everyone, Haven't posted on here, but I thought I would share my 2nd Gen integra with you all. Its a work in progress, but its coming along.
Old Oct 18, 2015 | 05:44 AM
  #54223
hb420's Avatar
Old Oct 18, 2015 | 11:52 AM
  #54224
Looks good man, Real good, I should have mine painted here soon, hopefully in likea month I'll have her ready
Old Oct 18, 2015 | 03:17 PM
  #54225
joeyjh4da9's Avatar
Real nice I agree...its coming along nice... https://honda-tech.com/appearance-bu...sucks-2216836/
pics wont load that's a bummer
