DA Integra's Only
Old Mar 3, 2015 | 08:07 AM
  #54176
MaltBeer's Avatar
Default Re: DA Integra's Only
Haven't posted here in a while...just wanted to run a quick question by you see if I can get any advice. I have a B18C in my car for a few years now. Never had any problems until a few days ago. Whenever I try to open it it won't let me go past 5.5k rpm it sounds like vtec is about to engage then my rpm needle drops to 0, the car bogs down and then the rpm's shoot back up again plus the check engine light comes on.
When the check engine light comes on my idle is higher just under 2k rpm and there is a really bad smell like the car is burning really rich or something. Anyone have any clues as to what this could be?
Plugs, cap, rotor all have been changed.
Old Mar 3, 2015 | 08:58 AM
  #54177
Colin's Avatar
Step one is to see what code it's throwing. It's not worth speculating until you have that info since it could be due to a myriad of things including mechanical timing (timing belt), ignition coil, igniter...
Old Mar 4, 2015 | 08:04 AM
  #54178
MaltBeer's Avatar
I was looking into doing that....I remember you had to pull back the carpet and count the number of flashes on the ECU if the car was a stock 91'. Because of the swap I believe I have to jump a wire?
Old Mar 4, 2015 | 12:36 PM
  #54179
Colin's Avatar
You really should see about obtaining a Helms Factory Service Manual.
For OBD0 you'll need to jump the service check connector (SCS) and then look for flashes on the ECU. For OBD1 you'll need to jump the SCS and then the CEL will flash the code. Do some google searches, you should be able to find a ton of tutorials and probably videos on youtube.
Old Mar 7, 2015 | 11:52 AM
  #54180
MaltBeer's Avatar
I have the Helms Manual. I found the connector behind the kick panel on the passenger side tried jumping it with the wire but it didn't work.
Old Mar 8, 2015 | 07:16 PM
  #54181
Brice.Hayden's Avatar
05 members.
Old Mar 9, 2015 | 07:06 AM
  #54182
MaltBeer's Avatar
05 members.
Tell me about it.
Old Mar 9, 2015 | 01:28 PM
  #54183
g2_teg_'s Avatar
2005???
Old Mar 9, 2015 | 06:30 PM
  #54184
I would have joined sooner but I thought G2IC was all I needed...
Old Mar 10, 2015 | 04:26 AM
  #54185
morganm58's Avatar
hmmm. Does the car stumble going up to 5.5k rpm? Not sure if these would cause you to go into limp mode. Car voltage ok? Are your Tpms and map sensor good? I wish you had the code.
Old Apr 16, 2015 | 02:53 PM
  #54186
gsilnc's Avatar
TBT!
havent been here in awhile
I went to the dark side lol
still got a soft spot for DAs
new thread! http://www.r3vlimited.com/board/showthread.php?t=352822
Old Apr 18, 2015 | 12:28 AM
  #54187
Welsh's Avatar
New wheels for new season
Bridgestone Avangarde + Michelin Pilot Sport Cup 205/50zr15
Old Apr 19, 2015 | 12:39 AM
  #54188
Jerimiah Styles's Avatar
Old Apr 19, 2015 | 08:08 PM
  #54189
Lord Helmet's Avatar
Originally Posted by Jerimiah Styles
Simple, clean, classic look I wish more DAs are this clean
Old Apr 20, 2015 | 06:39 AM
  #54190
Thank you.
Old Apr 20, 2015 | 10:37 AM
  #54191
Ef9vsDa9's Avatar
i have a pic of that da as my sreeen saver, love it!
Old Apr 30, 2015 | 06:27 PM
  #54192
anthonyfa18's Avatar
Default Re: DA Integra's Only (bergenholtzracing)
Originally Posted by xtrac1
I got my car back from Steen Chassis. They made a NASA Honda Challenge legal cage, mounted the seat, mounted the pedals with a platform for my heels to rest on, mounted the window net and extended the steering shaft.
They do excellent work and on time. Thanks Gary and crew!!
STAY TUNED!
heres some pics
bring back from the dead can any of know were i can find info on this build
Old May 3, 2015 | 04:05 PM
  #54193
nyckid's Avatar
Old May 3, 2015 | 06:19 PM
  #54194
91b18a1ls's Avatar
Out and about for the first time in a few months
IMG_1282 by AlwaysInVtec, on FlickrIMG_1283 by AlwaysInVtec, on Flickr
Old May 29, 2015 | 06:32 AM
  #54195
Gt limited(jdm approved)'s Avatar
my project 91
Old Jun 1, 2015 | 01:41 AM
  #54196
Jeffaj20's Avatar
Picked these up off craigslist!
Old Jun 20, 2015 | 04:42 AM
  #54197
Welsh's Avatar
Autofest in our town last weekend
Old Jul 9, 2015 | 07:49 PM
  #54198
91b18a1ls's Avatar
Got it on the dyno last week
Old Jul 11, 2015 | 07:19 AM
  #54199
Dyno Tune @ St00pidfast - YouTube
Very nice man, what was done to it?
Old Jul 11, 2015 | 09:46 AM
  #54200
91b18a1ls's Avatar
Thanks. Stock b16a (arp head studs, cometic head gasket), garrett 50 trim, 13lbs, on e85. That's about it
So after talking about getting a fire extinguisher for my car I finally got one =]
Found this automotive B & C grade one at Walmart for $15
I wanted to mount it close to the driver seat so if something happened it would be within easy reach. I ended up mounting it on the underside of the dash panel
I hope I NEVER have to use it, but it's a nice thing to have just in case something bad were to happen especially for just $15
