DA Integra's Only
Old Jun 22, 2012 | 08:20 AM
  #52251
OldSkoolDa91's Avatar
Default Re: DA Integra's Only
in for said duck face pics
Old Jun 22, 2012 | 10:07 AM
  #52252
Mattb16teg's Avatar
Community Builder
Community Influencer
^ Check your phone big boy! LOL
maybe later, kicking it old school tonight in the garage and doing some Edward 40 hands with the homies! Anyone local care to join!
Old Jun 22, 2012 | 04:27 PM
  #52253
tougetuned_ef's Avatar
Originally Posted by kiDchaos
I didnt know the G2's had a palmy gray interior. was surprised when i was pulling the interior out of one of my new parts cars and everything looked gray. Door sticker said palmy gray. Thought that was wild. I dont think i've ever seen this before.
wanna trade it for my blue rear seats and mint dark grey front seats?
Old Jun 23, 2012 | 07:17 AM
  #52254
kiDchaos's Avatar
mines a 4 door. not sure how much the rear seats differ. besides the driver seat isnt in the best of shape. The rest of the interior isnt too bad though.
Old Jun 23, 2012 | 08:18 AM
  #52255
hb420's Avatar
Da and Db rear seats are totally different and won't work without a shitload of mods to make it look correct.
Old Jun 23, 2012 | 09:30 AM
  #52256
kiDchaos's Avatar
kinda figured.
Old Jun 23, 2012 | 01:59 PM
  #52257
i just want some rear seats with head rests. less than a week and i will be behind the wheel of my da again!
Old Jun 24, 2012 | 05:30 PM
  #52258
MaltBeer's Avatar
Sup fellas thought I'd post this here in the DA section maybe someone encountered the same problem as I am having right now with the car.
I have a problem with the car not starting, or it does but randomly. The other day I went to start it and it was dead, tried to get a jump but it barely worked but finally got it started with a jump. Changed the battery and the next day same thing not starting. Weird thing is after I just about gave up trying to start it....it finally started again. I noticed when i was driving when i hit the brakes the inside lights were dimming and at one point the radio turned off. When I shut the car off and tried to turn it back on nothing....no electrics were on at all.
SO I ask if anyone knows what is wrong with it? Could it be some simple relay or fuse somewhere...? I changed the main relay fuse about 2 years ago with a OEM acura one. Any help would be appreciated.
Old Jun 24, 2012 | 06:08 PM
  #52259
thedb63's Avatar
alternator
Old Jun 24, 2012 | 06:58 PM
  #52260
check all your ground, especially the one on the thermostat housing. also check that all fuses are in correctly
Old Jun 24, 2012 | 07:17 PM
  #52261
Kevin's Avatar
Check the alternator, grounds and also have a look at the main fuses in the fuse box under the hood. I had a fuse that wasn't blown but it actually cracked inside and was barely making contact and caused all kinds of weird problems in the car. Also the main relay soldering can crack and cause intermittent issues. Typical DA stuff lol.
Old Jun 24, 2012 | 09:47 PM
  #52262
RABI_T89's Avatar
Originally Posted by EFcivicJDM
quick PS of a mugen ferio wing...
yes or no?..im liking it?
I've been wanting to see this! I have a few buddies with these on their civics. I like it on a da. I'd like to see more angles
Old Jun 25, 2012 | 07:31 PM
  #52263
that pic was photoshopped. he wanted to see what it would look like but its too short. he is deciding wether or not to cut one up or just scrap the idea
Old Jun 26, 2012 | 09:16 AM
  #52264
92NoTeC's Avatar
B, H/F and K series are the only ones you can buy mounts for.
Old Jun 26, 2012 | 06:52 PM
  #52265
91b18a1ls's Avatar
http://www.flickr.com/photos/alwaysinvtec/7445993056/http://www.flickr.com/photos/alwaysinvtec/7445993056/ by http://www.flickr.com/people/alwaysinvtec/, on Flickr
Old Jun 26, 2012 | 06:56 PM
  #52266
Default Re: DA Integra's Only (14secLS)
Originally Posted by llcool
Which engine fits in LS Integra ? My bro is looking for one. Just let me know please.
if your just looking to replace a stock motor you should find a b18a or b18b. should just drop right in with stock mounts. use all the stuff from the original motor like dizzy, alternator, and ps pump.
Old Jun 26, 2012 | 10:45 PM
  #52267
hb420's Avatar
Any b series would be the easiest swap fitment wise, if you happen to be close to philly pa I have a b18 b for sale with a 92 ys1 ls trans. 135xxx miles, new timing belt, water pump, valve cover gasket set, cam seal, intake mani gasket, throttle body gasket, water neck gasket, distributor, starter, spark plugs, spark plug wires, cap, rotor, axels and upper and lower rad hoses. $750
Hopefully I will be the owner of a new teg any day after friday
Old Jun 27, 2012 | 11:50 AM
  #52268
t minus 18 hours before i get on the road towards philly! my momo wheel will be in my grips soon! i need to hear some vtec ASAP!!!!!!
Old Jun 27, 2012 | 01:36 PM
  #52269
Builda'Teg_92's Avatar
Got some parts for my build!! hopfully the DA will be running by the end of summer. sry for all the pics
Old Jun 27, 2012 | 02:19 PM
  #52270
Originally Posted by Builda'Teg_92
what trans is this?
Old Jun 27, 2012 | 02:53 PM
  #52271
98 CTR. Pricy.
Old Jun 27, 2012 | 03:48 PM
  #52272
98 CTR. Pricy.
i bet it was! cant wait to see it together.
Old Jun 27, 2012 | 07:57 PM
  #52273
slammedg2's Avatar
well long day of work today just finished getting the fire wall out and a little bit off the rhd clip and she slide right in to place just weld it up tomorrow and go buy some seam sealer and start working on the bay n putting all the heater stuff back in lots of work i dont think ill ever do another one again its fun just have to get it roller to get it back into the garage
Old Jun 27, 2012 | 08:26 PM
  #52274
thedb63's Avatar
wishing mine was done...getting upset and losing patience because of this stupid recovery of back surgery
Old Jun 28, 2012 | 12:23 AM
  #52275
hb420's Avatar
I have about $3700 I saved for my silver teg for paint supplies and motor **** but I need another teg with ac lol
