DA Integra's Only
Old Mar 7, 2012 | 04:05 AM
  #51251
Colin's Avatar
Default Re: DA Integra's Only
Originally Posted by Mattyg2
Does anyone know the Spring dimensions for inner diameter and length on front and rear on the Ground Control setup?
Matt, GC uses standard 2.5" Eibach springs. I'm not sure of the length for the stock DA kit though. I think when I ordered mine they sent 8" springs but in the end I ended up using 6" or 7". If you give them a call they should be happy to answer any questions you may have.
*EDIT*
No idea if this is relevant or not to why you're asking for the above info... but I just saw that Jared mentioned in another thread that Eibach makes an adapter to allow the use of 2.5" springs on a coilover setup which normally runs 60mm springs.
Old Mar 7, 2012 | 08:50 AM
  #51252
FelipeIsJDM's Avatar
Thinking about buying this...
http://technet.ff-squad.com/how-to/5lug.ef-da/
or
http://www.ebay.com/itm/Acura-Integr...sories&vxp=mtr
Probably the second one since I like the wheel color better.
I think it's a good deal. Thoughts?
Old Mar 7, 2012 | 09:32 AM
  #51253
'92 Tegss's Avatar
Originally Posted by meugenkid95
[IMG][/IMG]
What suspension set-up you running bro if you don't mind me asking? Have any other shots?
Old Mar 7, 2012 | 11:22 AM
  #51254
SCRREEEAAAMMMM's Avatar
Originally Posted by EFcivicJDM
Where can I find this spoiler...
Old Mar 7, 2012 | 11:26 AM
  #51255
went to the junkyard but no front lips
[/QUOTE]
I think the 87-89 lip looks best on the 92-93 bumper.
Old Mar 7, 2012 | 11:43 AM
  #51256
HardLuckfoto's Avatar
http://www.ebay.com/itm/Painted-Acur...ht_2322wt_1017
Old Mar 7, 2012 | 01:36 PM
  #51257
hb420's Avatar
I think the 87-89 lip looks best on the 92-93 bumper.[/quote]
Which lip, there are two different ones between those years
Old Mar 7, 2012 | 01:43 PM
  #51258
Builda'Teg_92's Avatar
Wow, your pick apart is nice and tidy.....you cant even walk on the dirt at mine, just car parts ha
Old Mar 7, 2012 | 03:56 PM
  #51259
gsilnc's Avatar
i was looking for a 90-91 lip..... for my 91 front bumper.
and just that section was tidy lol
Old Mar 7, 2012 | 06:11 PM
  #51260
tougetuned_ef's Avatar
does anybody in the northeast or down to va have an oem 3dr exhaust in half decent shape? im flying back to philly in may and i want to drive the da back here to utah but there is no way i can drive it with the buddy club spec II on there. 2100 miles with that drone will put me to sleep. even if it has a hole i can patch will do. i might have to go to the junkyard to grab one but im trying to avoid getting under a car in the yard.
Old Mar 7, 2012 | 06:40 PM
  #51261
gsilnc's Avatar
dont know how much you're willing to pay but i got a stock muffler for $100
http://www.autopartswarehouse.com/sk.../BO278465.html
Old Mar 7, 2012 | 11:27 PM
  #51262
Bond's Avatar
Started to refinish a set of LS mesh rims I picked up a couple weeks back. Should be a long road, but I'm up for it. Sanding down all clear coat and hand polishing face of rim. Hopefully they come out good and I can buy a new set of Acura center caps. I thought about powder coating them a solid color but not sure it's the look I want. Just trying for a refreshed OEM look without paying huge money to have it done professionally.
Old Mar 8, 2012 | 12:22 AM
  #51263
Mattyg2's Avatar
*EDIT*
Thanks man. I need to change out my 12k 10k springs and was just wondering about the sizing. So tired of how stiff the car drives on the street. I'm probably going to get a 7k front and 6k rear setup. Just not sure on the length because I have that gap on the springs at the height I'm at now when the car is on jack stands.
Old Mar 8, 2012 | 05:59 AM
  #51264
Colin's Avatar
Oh man, welcome to my world. I've had that damn gap for way too long. I finally ordered a set of helper springs for my front suspension and I'll be installing those soon. The thing that you need to realize is that changing the length of the spring will not change the size of that gap. The gap will only change if spring rate changes or if the length of the shock itself changes (or if you change ride height). So, with that said, changing to a softer spring will reduce the gap that you have now, just not sure how much. You could however do some calcs to get a rough idea of what spring rate you'd need to run in order to get rid of that gap or to determine what the gap would be at a chosen spring rate. It won't be exact, but it'll get you in the right ball park. Since you're an educated man I'll assume you can figure out that math on your own, but if you need a hand, let me know and I can help you figure it out.
Old Mar 8, 2012 | 03:30 PM
  #51265
gsilnc's Avatar
muffler came in today :D
Old Mar 8, 2012 | 04:08 PM
  #51266
Mattyg2's Avatar
Are you going to center it?
Old Mar 8, 2012 | 04:26 PM
  #51267
gsilnc's Avatar
soon as i get more alcohol
Old Mar 8, 2012 | 05:57 PM
  #51268
Mattyg2's Avatar
I would paint the muffler semi gloss black and it will eventually turn a clean flat black color. It would look nice and clean that way. I painted my oem muffler before I took it off with it and it looked nice and fresh.
Old Mar 8, 2012 | 06:47 PM
  #51269
i need a whole exhaust cat back. i call my local dealer and the b-pipe is discontinued for some reason but the muffler can still be ordered. i would prefer stock but i might just buy the muffler from the dealer and then get the b-pipe from a local parts store.
Old Mar 8, 2012 | 07:03 PM
  #51270
Lookin good...I feel your pain ha
Old Mar 8, 2012 | 10:14 PM
  #51271
blackguy503's Avatar
hey guys kinda been gone for a while just got done moving in to my new apartment and enlistment!!
Old Mar 8, 2012 | 10:41 PM
  #51272
Size:  4.2 KB my DA picked it up for 1400
Old Mar 9, 2012 | 09:35 AM
  #51273
gsilnc's Avatar
sounds like a good idea thanks
Old Mar 9, 2012 | 09:39 AM
  #51274
gsilnc's Avatar
looks like a good find for 1400
Old Mar 9, 2012 | 12:37 PM
  #51275
~sp33~'s Avatar
EFB055
Looks clean.
