DA Integra's Only
Old Feb 26, 2012 | 01:43 PM
  #51101
Brice.Hayden's Avatar
Default Re: DA Integra's Only
Old Feb 26, 2012 | 01:50 PM
  #51102
HardLuckfoto's Avatar
Test fitted the Fittipaldi's on today..... Not sure if I'm gonna like that, hopefully they sit in a little more once its on the ground....
Old Feb 26, 2012 | 01:53 PM
  #51103
Turbo_Mits's Avatar
Originally Posted by Colin
Car looks great, I LOVE those wheels
Finding the rates you like is going to be subjective, so I don't think I need to suggested a specific rate combo. But I think you're for sure on the right track. What you're on now should be fairly comfortable and like you said, pretty balanced between under/oversteer depending on how everything else is setup. If you want to make it a little more mellow or safer for rainy conditions you could definitely go down to 450/350 and I think you'd still like it.
It's easy to get carried away with spring rates and lose focus on other things - like your driving. Or, even more importantly, that you may not have the "base" you need to even properly form an opinion on the spring rates you have and how the handling is. Ideally, I think the very first thing you should do to a DA in regard to suspension is bushings. I know it's not fun or glamorous, it's not necessarily cheap, and you don't get the looks that you do from lowering, but really its the most important thing with these cars. You could use $3000 external reservoir race shocks with perfectly matched spring rates and if your bushings are the stock worn out ones that car is going to handle like ****. If you haven't replaced all of your bushings, most importantly the rear trailing arm bushings, then don't even think about different spring rates, different sway bar sizes...etc...etc None of those other mods are going to perform properly or to their full potential until the foundation of the car is sound.
Stepping up to something like the poly ES bushings + OEM rear trailing arm bushings is affordable and will make a difference you can feel. But I'd have to say that now, with the availability of good quality hard rubber bushings (Hardrace) I'd go that route if it fits the budget. I'm currently going thru this process of changing from the ES bushings and Mugen RTA bushings that I've had for years and switching to Hardrace (except for the front LCA because Hardrace doesn't make a bushing for our front LCA's) plus PCI offset rear trailing arm bushings.
Agreed, but my current shocks are blown to ****, so this as much a repair as it is a well thought out modification for future work. I simply refuse to buy lifetime warrantied springs or shocks twice lol.
I picked up the car last month, and installed the wheels and tires. Im simply going part by part starting with what is most worn and/or annoying for the daily commute and working my way through the car.
Old Feb 26, 2012 | 01:56 PM
  #51104
Turbo_Mits's Avatar
Pic
Yikes... theres a hood rat! Shoot it! lol
Old Feb 26, 2012 | 02:03 PM
  #51105
Turbo_Mits's Avatar
Originally Posted by FelipeIsJDM
LOL! I love Honda Tech. Kaboom!
You actually kinda did ask for opinions if you think about it, didn't say anything about real-world experience with hard spring rates, but it IS true that stiff does not always make it faster. And yes, I had that same setup (Koni/GC with 380/250) on my old car and it was very good. I had Race shocks though. Felt perfectly stiff with a good set of polyurathane bushings (a very overlooked mod) and rear LCA's. If you want it really stiff then go for it. It sounds like you know what you want, so...
Try not to get angry this time.
And sorry I'm used to spring rates in KG/mm not in Lbs/in so that's what probably threw me. Next time I will use a conversion calculator. I see now that 350 is only like 6.4x
No anger... I said "No offence meant"... You simply said something ignorant.
Old Feb 26, 2012 | 02:12 PM
  #51106
91b18a1ls's Avatar
Originally Posted by DumaDA
What's your set up?
B16a with bolt ons, exedy oe clutch and exedy lightweight flywheel
Old Feb 26, 2012 | 02:21 PM
  #51107
90HondaDA's Avatar
Anyone have any preferences on hydro conversions as far as companies?
Old Feb 26, 2012 | 02:27 PM
  #51108
Originally Posted by Turbo_Mits
No anger... I said "No offense meant"... You simply said something ignorant.
...and i do mean with all due respect.
Old Feb 26, 2012 | 02:34 PM
  #51109
91b18a1ls's Avatar
I've got the hasport kit on mine. I've never had any issues with it, it does what it needs to do and works perfectly. Makes the pedal quite stiff, but i'm fine with that
Old Feb 26, 2012 | 03:13 PM
  #51110
90HondaDA's Avatar
The hasport is the cable adapter, i mean straight hydro. I currently have the hasport but at 450hp I'm pretty sure cables aren't going to last lol
Old Feb 26, 2012 | 03:21 PM
  #51111
91b18a1ls's Avatar
ok hasport also makes one that uses the slave cylinder. I don't see why a cable would care how much hp youve got. All it does is pull the clutch out and then release it. Doesn't really matter how much power the motor has. Plenty of people have 400hp+ and still use cable trans
Old Feb 26, 2012 | 04:57 PM
  #51112
swhangin's Avatar
Suja 1. Pretty exspensive but if you can fabricate its really simple to make. There is another company also but i forgot it. Sorry
Old Feb 26, 2012 | 07:23 PM
  #51113
http://www.ebay.com/itm/JDM-Honda-In...item19ce147692
Old Feb 26, 2012 | 09:46 PM
  #51114
91b18a1ls's Avatar
http://www.flickr.com/photos/alwaysinvtec/6787587666/http://www.flickr.com/photos/alwaysinvtec/6787587666/ by http://www.flickr.com/people/alwaysinvtec/, on Flickr
Old Feb 26, 2012 | 11:02 PM
  #51115
Bond's Avatar
I'll be running a simple 8k and 6k rear on my apexi n1 coilovers on my DA9. Was nice to roll on and dampening is adjustable.
I run koni yellow and GC setup on my 89 civic sedan. Currently I have 400 front and 300 rear. I do not have a rear sway bar as the car never had provisions for one. It's on my list of things to add/fabricate. I set up my alignment to adjust for the lack of rear sway and once I dialed in the koni's correctly it's a whole different car. I'd say it is very comparable to my DA. It understeers much less then the DA but mostly due to my alignment adjustments. I have also been playing with caster lately, but the rack at work is always busy.
In my DB1 I'm running koni reds and GC coilovers. This time off the shelf rates. Stock sways and nothing else. Vehicle has a hard time coming into down turns without understeering alot. The reds just aren't valved properly for these cars and springs. I won't be doing anything to this as it's a DD. I will be making adjustments on the rack and possibly getting a bigger sway up front. But then I'd probably swap springs out before doing that and up the rates all around.
Old Feb 27, 2012 | 07:04 AM
  #51116
Mattb16teg's Avatar
Community Builder
Community Influencer
I really want to switch to the koni/GC setup soon too!
My Omni Drags are killing me on the street.
Old Feb 27, 2012 | 07:34 AM
  #51117
OldSkoolDa91's Avatar
i have tein super streets but i have no clue at all what the spring rates are since they came on another car i got previously but kept them when i got rid of the car. they ride very nice though
Old Feb 27, 2012 | 09:53 AM
  #51118
Mattb16teg's Avatar
Community Builder
^ Wanna trade?! : P
Old Feb 27, 2012 | 11:14 AM
  #51119
SCRREEEAAAMMMM's Avatar
Here is my DA
Old Feb 27, 2012 | 11:17 AM
  #51120
Mattyg2's Avatar
Wheres the clear coat?
Old Feb 27, 2012 | 11:23 AM
  #51121
Flat black is what I was going for...
Old Feb 27, 2012 | 11:57 AM
  #51122
DumaDA's Avatar
Looks good flat black, some different wheels would set it off
Old Feb 27, 2012 | 04:43 PM
  #51123
projectTeG's Avatar
Originally Posted by SCRREEEAAAMMMM
Here is my DA
reminds me of mine from way back in the day
Old Feb 27, 2012 | 07:22 PM
  #51124
Originally Posted by Mattb16teg
^ Wanna trade?! : P
eh, i think i'm good. lol. i dont think my teins are goin anywhere anytime soon. i'd consider trading my tokico illumina's w/skunk2 coil overs, but not my teins
Old Feb 27, 2012 | 09:29 PM
  #51125
Boosted_hx00's Avatar
I like that black DA!
