DA Integra's Only
Old Sep 17, 2010 | 01:13 PM
  #42876
DumaDA's Avatar
Default Re: DA Integra's Only
why the **** does it seem like every time i try to use g2ic the server is always "Busy" i cant ever get on **** on that site
Old Sep 17, 2010 | 03:16 PM
  #42877
c_mack9's Avatar
that site has become completely F'in worthless. everytime i ask a question that one *** moderator chimes in and tells me to search. like i havent already and sorted through a million worthless threads that dont even relate to my topic because their search function sucks. its sad that it use to be such an informative site and now just sucks.
Old Sep 17, 2010 | 03:17 PM
  #42878
c_mack9's Avatar
i see youre selling your car and said you could remove parts? can i snag that front lip from ya?
Old Sep 17, 2010 | 03:19 PM
  #42879
DumaDA's Avatar
i'll see whats up, the 92 bumper looks kind of stupid without any lip on it but we may have one at our house hanging around somewhere, i'll check it out for you
Old Sep 17, 2010 | 04:01 PM
  #42880
c_mack9's Avatar
oh man thanks a lot!
Old Sep 17, 2010 | 04:38 PM
  #42881
negusjuda's Avatar
Originally Posted by hb420
Nothing but old school in the garage lol
give me those h22a injectors if you still have them on that motor
Old Sep 17, 2010 | 06:56 PM
  #42882
Mattb16teg's Avatar
Community Builder
Community Influencer
Put the car back together this afternoon, the oil drain was a pain!
NCSI came over to hang out too.
Took the car out tonight to drive around and had a blast : )
Old Sep 17, 2010 | 07:36 PM
  #42883
OldSkoolDa91's Avatar
so all is good now matt??
Old Sep 17, 2010 | 08:05 PM
  #42884
Mattyg2's Avatar
Detailed the interior and trunk
Old Sep 17, 2010 | 08:13 PM
  #42885
soupE__'s Avatar
nice
Old Sep 17, 2010 | 08:16 PM
  #42886
Edgar206's Avatar
cmack9 i had one for u cheap too but u didnt want it..
Old Sep 17, 2010 | 08:22 PM
  #42887
damn matty that thing looks like it came off the show room floor!
Old Sep 17, 2010 | 08:32 PM
  #42888
c_mack9's Avatar
yeah thanks man but i need one in a little better shape.
Old Sep 17, 2010 | 09:35 PM
  #42889
bonspeed's Avatar
wish my interior was mint like that...
Old Sep 17, 2010 | 11:04 PM
  #42890
Mattyg2's Avatar
It can get like that, takes a lot of time and care!!! I'm still not done.
Old Sep 18, 2010 | 05:15 AM
  #42891
projectTeG's Avatar
you do know that most h22a injectors are the same as a B/d/f right?
Old Sep 18, 2010 | 06:17 AM
  #42892
i thought h22 injectors were like 290 or 310s?? could be wrong...
Old Sep 18, 2010 | 07:51 AM
  #42893
be18see1's Avatar
Yeah, I think they're 290cc. However, projectTEG has the H22 here so...
Old Sep 18, 2010 | 07:52 AM
  #42894
projectTeG's Avatar
OBDI = peak and hold 345cc
OBDII = saturated 290cc
my bad i was thinking h23
Old Sep 18, 2010 | 07:59 AM
  #42895
be18see1's Avatar
If you figure out how to make those seat belt buttons look red again, please let me know. I cleaned up my interior and I could never figure out how to bring them back to life!
Old Sep 18, 2010 | 08:02 AM
  #42896
tegtuner01's Avatar
ok guys i have a dumb question. My 90 DA is throwing a code and i'm not sure what it is. It only throws the light after i'm driving for a while. it doesnt throw it when i'm idling. any ideas?
Old Sep 18, 2010 | 08:12 AM
  #42897
Papa Lazarou's Avatar
Originally Posted by Papa Lazarou
I recently bought a 1990 DA6 and have a slight issue with the drivers door window/seal and wondered if you guys might be able to help.
When you close the door, the window doesn't pop under the seal properly so you have to close it with the top of the window to get it to sit correctly.
Ok, so it seems there are 2 trains of thought on this - either adjust the window or replace the weather strip.
When i close the door with the window up and the gap is present (only at the back end of the window), i can lower the window slightly with the switch and the glass pops back into line again and sits flush with rubber seal on the door aperture. I then raise the glass with the switch and there is no gap.
It's as if the rear 1/3 of the weather strip is stopping the window from going all the way in. The front of the glass sits under the strip correctly, but it passes under the strip and to the wrong side of it as it progresses to the rear of the door.
If i close the door with the window down slightly and then raise the window, the glass goes under the weather strip correctly. This must point to the glass alignment being ok and the weather strip being the problem - would anyone agree with that?
Sorry to keep asking, but as someone mentioned up there ^, searching on G2IC isn't the easiest of things to do. I'm not being a lazy ***, i have looked.
Does it sound like i need to adjust the top of the window inwards?
Or does that fact that the glass sits correctly when you drop it then raise it (or close the door with the window down slightly, then raise the glass) mean that it's more of a weather strip issue?
Old Sep 18, 2010 | 08:29 AM
  #42898
Mattb16teg's Avatar
Community Builder
FINALLY got my dump tube made. Turned out good!
Old Sep 18, 2010 | 10:31 AM
  #42899
Ef9vsDa9's Avatar
mine did that too, it was my speed sensor popping out. the ten had came out.
hope this helps
Old Sep 18, 2010 | 10:50 AM
  #42900
Mattyg2's Avatar
don't think there's nothing you can do about those.
