DA Integra's Only
Old Sep 12, 2010 | 10:09 PM
  #42776
bonspeed's Avatar
Default Re: DA Integra's Only
there's no issue with the engine, he just wants to sell it because he was supposed to swap it on his EK hatch but ended up trading the EK hatch for an EG hatch Si with a JDM GSR engine.. and yeah it has the distributor and all the engine harness.. my problem now is converting it to Obd1, because my DA is Obd1 already and i don't want to downgrade to Obd0...
Old Sep 12, 2010 | 11:00 PM
  #42777
Ef9vsDa9's Avatar
thats a good price
Old Sep 12, 2010 | 11:23 PM
  #42778
Mattyg2's Avatar
Pin and wire all your OBD1 connections stuff to the engine harness on the motor.
My autox vid from today. I know my camera setup sucks but whatever. Smashin though..
http://www.youtube.com/watch?v=rRpkaiCCeHA
Old Sep 13, 2010 | 12:24 AM
  #42779
Papa Lazarou's Avatar
Originally Posted by Mickeeezy
There's a DIY on G2iC that tells you how to fix that.
I've had a look on there but i can't find anything. Guess i'm not looking hard enough.
I'll have another search but if you have a link it would be appreciated.
EDIT:
Ok, so it seems there are 2 trains of thought on this - either adjust the window or replace the weather strip.
When i close the door with the window up and the gap is present (only at the back end of the window), i can lower the window slightly with the switch and the glass pops back into line again and sits flush with rubber seal on the door aperture. I then raise the glass with the switch and there is no gap.
It's as if the rear 1/3 of the weather strip is stopping the window from going all the way in. The front of the glass sits under the strip correctly, but it passes under the strip and to the wrong side of it as it progresses to the rear of the door.
If i close the door with the window down slightly and then raise the window, the glass goes under the weather strip correctly. This must point to the glass alignment being ok and the weather strip being the problem - would anyone agree with that?
(sorry for the wordy post, i'm just trying to describe the issue as best i can)
Old Sep 13, 2010 | 02:59 PM
  #42780
aquito's Avatar
Installed my $20 enkei 83"s on my DA..what u guys think?
Old Sep 13, 2010 | 03:38 PM
  #42781
HeLLa iLL2ndGen's Avatar
Paint looks great, just needs to be lowered and as for the rims they suit the year of the car but not my style
Old Sep 13, 2010 | 04:32 PM
  #42782
Mattb16teg's Avatar
Community Builder
Community Influencer
Got the car back together for the most part. Just need to tighten up some things tomorrow.
Had to force in a bolt on the head because the first threads were a bit tough.
Old Sep 13, 2010 | 07:05 PM
  #42783
OldSkoolDa91's Avatar
agreed
keep it on the road this time!! lol
Old Sep 13, 2010 | 07:14 PM
  #42784
bonspeed's Avatar
nice run!
if i do this, i won't be able to use the ECU that came with the ls/vtec anymore right?...
Old Sep 13, 2010 | 07:28 PM
  #42785
aquito's Avatar
I know the rims are not that nice but can't beat rolling on $20 rims lol
Old Sep 13, 2010 | 07:29 PM
  #42786
no, no you cant. unless they are free. lol
Old Sep 13, 2010 | 07:31 PM
  #42787
bonspeed- how is the engine currently set up? obd0, obd1 or obd2?
Old Sep 13, 2010 | 09:00 PM
  #42788
bonspeed's Avatar
the ls/vtec?.. it's Obd0 and originally obd0 along with the ECU..
Old Sep 13, 2010 | 09:09 PM
  #42789
ok. and you said your car is obd1. simple. use the factory harness from you car. add the wires you need for vtec. either get your obd1 ecu chipped for vtec or buy an obd1 vtec ecu (a good chip and tune def. wouldn't hurt to go along with this). get an obd1 dizzy. should be good to go.
people make converting engines between obd's a lot harder than it really is...
Old Sep 13, 2010 | 09:44 PM
  #42790
bonspeed's Avatar
thanks for the info.! my friend has a spare p28 ECU and is willing to lend me his ECU... will my LS dizzy work? or i should really get an obd1 vtec dizzy?...
Old Sep 13, 2010 | 10:09 PM
  #42791
the p28 will work, but the mapping wont be correct for the ls/v. best route with that is to get it chipped with a good ls/v map. any good tuner can hook you up with a good map, but still recommend an actual tune since every engine is different.
as for the dizzy... you can make the ls dizzy work, but you will have to modify the mounting tabs. there are a lot of guys who just cut the 2 lower ones off and only run 1 bolt at the top. im not a fan of this personally, but a lot of people do it without problems. the choice on what you do dizzy wise if up to you n what you feel comfortable with
Old Sep 14, 2010 | 04:08 AM
  #42792
Mattb16teg's Avatar
Community Builder
Meanie!
Yea hopefully! My boy NCSI is coming up from NC this weekend and I look forward to showing him what a quick DA feels like
I'm currently only running one bolt but just need to go to lowe's and grab another. I was only running 2 however 1 decided it wanted to leave.......
Old Sep 14, 2010 | 08:04 AM
  #42793
EFcivicJDM's Avatar
alri guys i currently have 15x7 +20 offset rims...but i want wider mabye 8 inchs shoul i keep the same offset???
i just want them flush with the arch..lookin at 15x8 bbs rms but dont know what offset they are
Old Sep 14, 2010 | 08:23 AM
  #42794
you gotta keep your car together first matt
lol, but seriously, i hope it doesnt give you anymore problems now and you can finally enjoy it
Old Sep 14, 2010 | 08:44 AM
  #42795
Mattb16teg's Avatar
Community Builder
burnnnnnnnnnnnnnnnnnnnnn, assshat!
Old Sep 14, 2010 | 11:30 AM
  #42796
hey, i gave you a no homo hug, thats gotta count for something! lol
Old Sep 14, 2010 | 11:59 AM
  #42797
Mattb16teg's Avatar
Community Builder
Looked pretty homo to me........... Jussayin!
Old Sep 14, 2010 | 12:49 PM
  #42798
Hydro_Da's Avatar
Haven't stopped in here since i sold my da back in July, still miss her.
Guts for sale. Local preffered.
http://forums.g2ic.com/showthread.ph...luster-no-ship
Old Sep 14, 2010 | 12:56 PM
  #42799
Mickeeezy's Avatar
Shoulda kept her.. she was a beaut.
Old Sep 14, 2010 | 02:00 PM
  #42800
ncsi's Avatar
Dick! you only got like 65whp on me :p damnit lol CANT WAIT for MD though gonna be fun!!!!!
