DA Integra's Only
Old Mar 11, 2010 | 09:19 AM
  #37326
AllmansDB8*'s Avatar
Default Re: DA Integra's Only
good, I'm happy you got that all worked out!
Old Mar 11, 2010 | 09:52 AM
  #37327
DumaDA's Avatar
yeah haha finally the car runs the way its supposed to, now just need a vtec head haha
Old Mar 11, 2010 | 10:04 AM
  #37328
b16-ef-si's Avatar
or boost
Old Mar 11, 2010 | 10:09 AM
  #37329
DumaDA's Avatar
not on a b20 with stock sleeves
Old Mar 11, 2010 | 10:40 AM
  #37330
kNOwLedGe.'s Avatar
And a block rebuild with stronger connecting rod bolts.
Old Mar 11, 2010 | 10:46 AM
  #37331
DumaDA's Avatar
i didnt mean, just a vtec head lol, the list would be....
vtec head, arp headstuds, oil line, headgasket, gsr oil pump, gsr water pump/timing belt, arp rod bolts, obd1 conversion harness +ecu +dizzy probably leave it at that and run stock internals besides the rod bolts
Old Mar 11, 2010 | 10:58 AM
  #37332
1200 Hobos's Avatar
Maybe a GE block guard too for piece of mind and shot peen the rods.
Old Mar 11, 2010 | 11:22 AM
  #37333
kNOwLedGe.'s Avatar
It doesn't make much sense to crack open the block to change the connecting rod bolts and not upgrade your pistons.
Old Mar 11, 2010 | 11:24 AM
  #37334
be18see1's Avatar
I built a b20 bottom which made greeeaatt power (238 whp, 150+ tq) with a ported vtec head with s2s2 cams. One thing I skipped that I would recommend you do is the block girdle, like what's on the b18c motors. Stay away from block guards on b20's because they tend to put the sleeves in tension and cause cracking. Lastly, he's right about no boost. Boosted b20's don't last.
Old Mar 11, 2010 | 11:26 AM
  #37335
DumaDA's Avatar
if i was going to do all that work i'd probably pick up a spare block and head and work on it slowly, i wouldnt use the motor that i daily haha
Old Mar 11, 2010 | 11:38 AM
  #37336
1200 Hobos's Avatar
Check out my buddies build. CTR Cams 3 angle basic valve job not even ported and he made 234hp and 170lb torque at the hubs.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/%2A%2A%2A%2A%2A%2A%2A%2A%2A%2A%2Ab20vtec-build-dyno-graph%2A%2A%2A%2A%2A%2A%2A%2A%2A%2A%2A%2A%2A-2486531/
Put together by edomoto, <--- check link in my location. Sadly he never got the chance to use it to it's full potential, the car was stolen about a week after the build.
BTW have you seen this in person about the block guard? I'm just wondering, I never heard about that problem.
Old Mar 11, 2010 | 11:50 AM
  #37337
DumaDA's Avatar
god damn, it looks like once vtec cracks he gains about 50whp in 1k rpm
Old Mar 11, 2010 | 02:14 PM
  #37338
Mattb16teg's Avatar
Community Builder
Community Influencer
https://honda-tech.com/forums/showthread.php?t=2486531
I'm not trying to be a "hater" but I find it very hard to believe it made that much power on OEM ctr cams........
Old Mar 11, 2010 | 02:16 PM
  #37339
Brice.Hayden's Avatar
those cams won't make power past 9000 and usually won't make more than 200 on any setup.
Old Mar 11, 2010 | 02:38 PM
  #37340
projectTeG's Avatar
i can believe it. on a 2 liter, because base b16 cams can peak alil over 200 whp on a 2.0. plus that dyno is to the hubs so its more than thte whp reading if it were a rolling dyno
Old Mar 11, 2010 | 02:41 PM
  #37341
1200 Hobos's Avatar
I know! It was a very special motor. Swapped off the street just one week after the build finished. He had several layers of theft protection too but it was probably towed. The chassis was never found.
Factor in 13-14% powertrain loss, still a very potent build.
Don't take my word for it. I'm just showing you guys what else is out there. Whether you believe it or not is completely up to you. I'm no bullshitter and I wouldn't have posted this in the first place if I didn't have 100% confidence in the builders skill level and that the results were true.
https://honda-tech.com/forums/showpo...3&postcount=20
Old Mar 11, 2010 | 03:23 PM
  #37342
DumaDA's Avatar
yeah you seem like a person who knows their ****, i cant imagine the feel of an increase of 50whp in the span of only 1k rpm, that must have felt amazing
Old Mar 11, 2010 | 04:01 PM
  #37343
DumaDA's Avatar
hey guys, need some advice.
So i think im ready to put in some work and sand the paint off my front and rear moldings, what would be the best way to go about that, should i just tape it off and go to down with the sandpaper or is there a better/easier way etc.?
Old Mar 11, 2010 | 04:18 PM
  #37344
hb420's Avatar
Tape it off and sand the moldings with a automotive red scotch brite pad. You can get them at any auto parts store
Old Mar 11, 2010 | 04:19 PM
  #37345
yeah with 34hp loss for 15% drivetrain that makes a 234 = 200hp to the wheels. which is totally believeable.
Old Mar 11, 2010 | 04:28 PM
  #37346
OldSkoolDa91's Avatar
Originally Posted by ProjectJDM
1200 Hobos- replied to your pm. It's a 2 1/2 I was going to go 3" since I plan on boosting in the future but it would be too loud NA and I like to drive my car around.
As for the hood prop, I'm not happy with it either. If I had a choice I wouldn't prop it at all but I need to do it to clear the H2B setup. At that height, it still tends to hit if you slam the hood.
my bad...didnt realize it was h2b
i think its necessary for his h2b set up. Edit: i didnt even see his post right above mine lol
on another note, got my car back today, they put the transmission in, hooked me up with another half shaft and axle, and put my polyurethane insert into my rear mount, car feels great now
glad it all got taken care of finally
just drove to work with the new motor and trans running the way they're supposed to, it was pretty fun, shifting at 6.5 and it only drops to 5.5 and keeps going haha
good deal! i'm kinda dreading searching for a vtec cable trans when it comes time to find one for my ef... getting harder and harder to find a good one anymore
Old Mar 11, 2010 | 04:40 PM
  #37347
Mattyg2's Avatar
I'll sell you mine so I can build a YS1 setup
Old Mar 11, 2010 | 04:53 PM
  #37348
DumaDA's Avatar
k cool, imma get that started this weekend then, if i have enough time paint the grill on my bumper back to black too, never weekend i'll be refinishing my wheels, picking up the lug caps on sat/sun
Old Mar 11, 2010 | 04:55 PM
  #37349
slammedz6ef's Avatar
well i guess ill go.......lsv da stock gsr head
Old Mar 11, 2010 | 04:56 PM
  #37350
YS1 FTMFW!!!!!!!!!!!!!
