***********b20vtec build and dyno graph*************
Old Jan 28, 2009 | 10:33 PM
vtecnuts's Avatar
Default ***********b20vtec build and dyno graph*************
hey all im pretty new to HT but this is the build
b20 b block
golden eagle block guard
spark racing itr pistons 84.5
ls crank
ls rods
acl race bearings
arp studs all around
oem head gasket
golden eagle vtec kit
b16a2 head
ctr valve springs
ctr cams
skunk cam gears
valve job
itr intake manifold spoon tb
h22 injectors
spoon header
http://
http://f.imagehost.org/view/0283/final_numbers
Old Jan 28, 2009 | 10:35 PM
1.5Slowmatic's Avatar
Default Re: ***********b20vtec build and dyno graph*************
im gettin red x's
Old Jan 28, 2009 | 10:39 PM
vtecnuts's Avatar
red x where?
working now?
Old Jan 28, 2009 | 10:48 PM
EdoMoto's Avatar
Old Jan 28, 2009 | 11:17 PM
Combustion Contraption's Avatar
MMMM, 234hp on CTR cams huh...
If all those runs on the graph are yours, how did you find 40hp @ VTEC xover?
Old Jan 28, 2009 | 11:21 PM
vtecnuts's Avatar
all the runs are mine the first runs were from stock jdm obd2a itr ecu
then after we switched over to hondata s200 and started tuning
Old Jan 28, 2009 | 11:27 PM
WOW, Im going to have to hit up Todd and ask him what he set those CTR cams to to pull 235hp out of em.
Old Jan 28, 2009 | 11:29 PM
vtecnuts's Avatar
todd did do the tuning !!!! i watched him and bugged him the whole time ! hahahahah
Old Jan 29, 2009 | 03:37 AM
egb18c5's Avatar
there's no words to describe how high this dyno read
Old Jan 29, 2009 | 05:19 AM
OH_1fstgsr's Avatar
Doesn't a DynoPack read about 12-15% higher compared to DynoJet?
Old Jan 29, 2009 | 07:57 AM
vtecnuts's Avatar
todd told me about 8 percent...
Old Jan 29, 2009 | 10:18 AM
Im just going to come out and say it vtecnuts, since you didnt catch the sarcasm. Theres no way you hit 235hp on that dyno with CTR cams. Todd did a test a while back on his fully built , sleeved GSR build, and with stock B16 cams, and better supporting mods than you, he managed 200hp. No way did you find 35hp with less supporting mods, and slightly more aggressive cams.
https://honda-tech.com/forums/showth...highlight=cams
Old Jan 29, 2009 | 10:33 AM
vtecnuts's Avatar
lol u think i have bigger cams ? lmfao u guys are a joke ! i wish i had the money for cams ! its not just what parts u use.. its how u build it...
Old Jan 29, 2009 | 10:36 AM
vtecnuts's Avatar
head work was done by west coast and the block work was done by the balance shop ! motor was put together in a house garage.
Old Jan 29, 2009 | 10:42 AM
EdoMoto's Avatar
Looks like he also used snake oil that adds 20% more power than any other supporting mods.
Edo
Old Jan 29, 2009 | 10:56 AM
OK, you probably have the record for highest hp on a 2 liter w/ CTR cams. Or any NA motor w/ CTR cams for that matter.
Old Jan 29, 2009 | 11:03 AM
logg_frogg's Avatar
If you take a look at the Graphs closely it says *fly wheel HP, fly Wheel TQ*
if you take away 20% for drivetrain loss you get 188ish hp which would make alot more sense
although i don't wanna know how you get flywheel power from a chassis dyno lol..
Old Jan 29, 2009 | 11:05 AM
logg frogg, it says flywheel hp and flywheel TQ, but thats because the software puts it there. The power on a dynapack is measured at the hubs, and usually reads 8-10% higher than a typical dynojet, like a 248C. Honda BVTEC drivetrain losses arent 20% by the way, more like 13-14%.
Old Jan 29, 2009 | 11:29 AM
alterdcreations's Avatar
any pic's of the head work?
Old Jan 29, 2009 | 12:26 PM
b19coupe's Avatar
Icon4 Re: ***********b20vtec build and dyno graph*************
The motor really did put down those numbers and the cams sure did act like CTR/ITR cams. VTEC with the short ram was at 4450. We were able to drop VTEC to 4100 with the AEM ITR CAI.The blue line was with the customer's crappy short ram and dirty air filter. The yellow line was with the CAI. You can see that with the ITR ECU, VTEC at 5,700 was way too high. We picked up about 40 HP and 40 ft-lbs. of torque at 5,700 by dropping VTEC (as well as the fuel ignition tuning). Even Shawn was impressed with this motor.
Yes our dyno reads higher than a Dynojet, as it should. By bolting directly to the hubs the dyno eliminates tire/wheel inertia as well as alignment/tire pressure/strap down variables. An engine dyno reads even higher than the Dynapack, perhaps we should question the validity of engine dyno numbers...
Yes, Steve, I only made 212 with B16 cams on my 2 liter. But that was with a stock LS exhaust manifold, catalytic converter, and muffler IIRC.
Old Jan 29, 2009 | 12:37 PM
Its.....
Surprising to say the least. Looking at the graph I would guess VTEC is at 5700 or so, but I would guess thats just the baseline. I remember you making 212, but you also had more motor, ported intake manifold and probably better headwork.
Old Jan 29, 2009 | 12:39 PM
vtecnuts's Avatar
thank u Todd for the great work ! and i did not notice you at first but now i c ur screen name .. i have done business with you b4.. i believe i bought a k series oil pan from u once. ! and maybe other things for this motor you tuned.. i cant really remember !
Old Jan 29, 2009 | 12:42 PM
In any case, Todd has confirmed its genuine and this does look to be a special build. Congrats on the motor. With this strong of a baseline, you would be 'vtecnuts' not to drop some cams in there and spin it higher.
Old Jan 29, 2009 | 12:49 PM
Professor15's Avatar
thats pretty damn impressive for just CTR cams and lil headwork...
Old Jan 29, 2009 | 01:16 PM
vtecnuts's Avatar
i do not have pics of the head work... and its using stock valves.. only the intake side was worked on. intake manifold is stock itr. not ported or matched ! i dont know about installing cams.. but maybe a oil cooler for road racing !
