BUILT NOT BOUGHT!
Old Sep 27, 2011 | 05:18 PM
  #6651
91sedan_kid's Avatar
Default Re: BUILT NOT BOUGHT!
just saw the pics! really sucks bro. keep us updated on what you do!
Old Sep 27, 2011 | 05:24 PM
  #6652
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
ugghhhh tired of being sick,tired of antibiotics, tired of no energy to work on the car, this sucks, here we go with round four on the antibiotics
Old Sep 27, 2011 | 05:27 PM
  #6653
GlassJAw's Avatar
Have just found out my P30 is an auto ECU, which is good and bad from what I can tell.
Means when I chip it I don't have to solder in one chip..... but also means I'm running roughly 10 less hp??
Is there any truth to that last statement??
Old Sep 27, 2011 | 07:27 PM
  #6654
SLOENUF's Avatar
here is my 99 integra. im the 2nd owner, picked it up bone stock from an older couple earlier this year. had timing belt and water pump replaced at 100k. sitting at around 142k now.
how it sits now.
-yonaka catback
-ebay short ram
-ddm 6k hids
-superbright leds for the cluster
future plans
-suspension
-gsr or b16 tranny
-maybe b&m dual bend shifter.
-either vtec head swap with cams and full bolt ons or just piece together a turbo kit for the ls
Old Sep 27, 2011 | 07:35 PM
  #6655
Or you can do a vtec head swap and then turbo it!
Old Sep 27, 2011 | 07:41 PM
  #6656
BrayzieEF9's Avatar
Wassup BNB? Just checking in.
Old Sep 27, 2011 | 07:46 PM
  #6657
SLOENUF's Avatar
very true but if im gonna go that route i might as well just build it then. if i go the turbo ls route im gonna stick with stock internals. only shooting for 300-350whp. if anything id do arp rod bolts
Old Sep 27, 2011 | 08:55 PM
  #6658
My setup is a stock internal Lsv turbo and its making 250 on 10 psi.
my cousin had a stock internal lsv turbo setup and it barely made 300 on 15psi. Motor didnt last.
all im saying is its going to be tough making 300-350 on stock internal and still have it be reliable. i recommend doing a mild build to handle the power.
Im planning on doing a mild build on my motor next year and upping the boost to make 350.
Old Sep 27, 2011 | 09:43 PM
  #6659
My_EFsedan's Avatar
the head can be stock. just the block needs to be built if your only going for 300-350. it'd be easier with a vtec head too. stock internal is fine if you dont beat it. good tune and its good to go.
my motor was tuned @ 13 psi and made 295. but on a stock map sensor which only allowed 11psi max. so it wasnt making the power i wanted cause i couldnt go anymore than 11. had boost creep, then fixed it allowing me 15 psi lowest on the spring and never retuned. boom threw a rod running lean.
Old Sep 28, 2011 | 07:01 AM
  #6660
90HondaDA's Avatar
just go for some pistons and rods, for the bottom end then mayb look into springs and retainers for the head, not an entire build but enough to def help out
Old Sep 28, 2011 | 10:45 AM
  #6661
pretty much what i had in mind.
Old Sep 28, 2011 | 11:43 AM
  #6662
OldSkoolDa91's Avatar
no offense, but if you guys are struggling to get 300 on a stock ls/v setup, something is wrong somewhere. getting 250 on 10lbs is what most stock ls's do without a vtec head on them with a somewhat decent setup. and if you go look in the turbo b18a/b ls thread on here, you'll see a lot guys taking bone stock ls's to 300+ with no problem and having them last for quite some time. sounds to me like you guys didnt have the greatest tunes. again, this is no offense to anyone, but this is coming from what i see all the time both personally and second hand.
also, if to the guy with the integra, if you're gonna go ls/v, rod bolts are a MUST if you dont want to spin bearings from the extra rpms
Old Sep 28, 2011 | 12:11 PM
  #6663
SLOENUF's Avatar
thats where i have been looking. thats why i figured with a good tune i should be right where i wanna be. figure ill do the rod bolts as extra security.
Old Sep 28, 2011 | 12:38 PM
  #6664
My_EFsedan's Avatar
my problem was, my wastegate spring was 15 psi spring lowest and i made the mistake to go there with a stock map sensor. so the tune was way off. because i wasnt able to go more than ~11 psi on the map. i could of made 350 easy.
Old Sep 28, 2011 | 03:47 PM
  #6665
I got the setup from a friend and he was the one that got it tune. he said it made 250 on 10 psi but when i swap everything into my car and had a working boost gauge, it was only reading 6psi. i never touched the boost controller the entire time we did the swap and the only way you can turn it up or down with that boost controller was with an hex key. Also my friend got it tune with stock piping by DNR.
Im not 100 percent sure if thats what it really made im just going with what he told me.
I havent got it tune yet because i wanna upgrade piping and upgrade turbo first. Also looking to do a mild build next year so i might as well just wait until everything is done and get it tune all at once. car drives fine and pulls good so imma just wait it out.
Old Sep 28, 2011 | 04:02 PM
  #6666
DumaDA's Avatar
having the stock piping on the car held it back quite a bit during tuning im sure, plus isnt the turbo thats on there pretty small?
Old Sep 28, 2011 | 04:52 PM
  #6667
90HondaDA's Avatar
Yeah i see ppl making like 300 on 11 psi then i see ppl who make 300 on 22psi... alot of times its all about the tune, a great tune can make or break your numbers. I have seen bigger numbers on lower boost because the time spent on a proper tune was there.
Old Sep 28, 2011 | 04:53 PM
  #6668
Mrevann's Avatar
GDD Black Reject
gonna be picking up a GSR for 6500 from a really close friend... let you guys know the spec in a few
Old Sep 28, 2011 | 05:01 PM
  #6669
Mrevann's Avatar
GDD Black Reject
96 GSR. Clean Title 5 Lug Conversion Compustar alarm Tein SS suspension with pillowball Mounts in the front Omni power LCA's and Omni Camber kit in the rear.... Type R Misc. Parts in the Inside Type R Front seats and Floor Mats CF Whale ***** with J's Racing Filter. Engine is super stock i can vouch ive been in it. i will be the 3rd owner of the car if i was to buy it .. oh and 122000 miles on it. ...
Old Sep 28, 2011 | 05:32 PM
  #6670
The turbo is hella small compared to my other turbos. And post pic of the gsr so we can get a better idea of 6500.
Old Sep 28, 2011 | 05:52 PM
  #6671
Mrevann's Avatar
GDD Black Reject
Old Sep 28, 2011 | 05:53 PM
  #6672
Mrevann's Avatar
GDD Black Reject
sorry about the first picture he sent that one today other 2 i took when i was in WA for a weekend.
Old Sep 28, 2011 | 06:37 PM
  #6673
ek9kenny's Avatar
how she sits today
Old Sep 28, 2011 | 07:32 PM
  #6674
My_EFsedan's Avatar
i think you need to send some of the negative camber to the front and lower the car more to pull of those wheels.
Old Sep 28, 2011 | 07:53 PM
  #6675
x2.
also the gsr looks coo. i dont think i would ever pay 6500 for an integra but i thats just me.
