BUILT NOT BOUGHT!
Old Sep 28, 2011 | 08:36 PM
  #6676
OldSkoolDa91's Avatar
Default Re: BUILT NOT BOUGHT!
Originally Posted by SLOENUF
thats where i have been looking. thats why i figured with a good tune i should be right where i wanna be. figure ill do the rod bolts as extra security.
you can def learn a LOT from that thread.
Originally Posted by My_EFsedan
my problem was, my wastegate spring was 15 psi spring lowest and i made the mistake to go there with a stock map sensor. so the tune was way off. because i wasnt able to go more than ~11 psi on the map. i could of made 350 easy.
yeah its funny how much a map sensor will hold you back. local guy i know has a rod/piston bottom and never bothered to get a bigger map so he didnt make anywhere near what his bottom end was capable of holding.
Originally Posted by 91sedan_kid
I got the setup from a friend and he was the one that got it tune. he said it made 250 on 10 psi but when i swap everything into my car and had a working boost gauge, it was only reading 6psi. i never touched the boost controller the entire time we did the swap and the only way you can turn it up or down with that boost controller was with an hex key. Also my friend got it tune with stock piping by DNR.
Im not 100 percent sure if thats what it really made im just going with what he told me.
I havent got it tune yet because i wanna upgrade piping and upgrade turbo first. Also looking to do a mild build next year so i might as well just wait until everything is done and get it tune all at once. car drives fine and pulls good so imma just wait it out.
if it's only truly on 6 pounds and its a smaller turbo, then that makes perfect sense why the numbers would seem low. get those things straightened out and you should put down some very nice numbers
Originally Posted by 90HondaDA
Yeah i see ppl making like 300 on 11 psi then i see ppl who make 300 on 22psi... alot of times its all about the tune, a great tune can make or break your numbers. I have seen bigger numbers on lower boost because the time spent on a proper tune was there.
exactly!
Old Sep 28, 2011 | 10:03 PM
  #6677
91sedan_kid's Avatar
yea it was only boosting 6psi on a .50 trim turbo. Im going to be picking up a .57 trim turbonetic hopefully friday.
engine plans for next year are:
- rebuild head with type r internal or stock b16 internals.
- rebuild block with
- 84mm cp piston
- eagle rods
- acl race bearing
- arp rod bolt
- stock LS micro polish crank
- stock sleeve
- Upgrade to 2.5" piping from downpipe back
- Retune and shooting for 350hp.
plan for car next year.
- D2 or FFtype1
- blox LCA
- engine bay painted teal
- wire tuck
- mugen rep front lip
- spoon rep rear lip
- POSSIBLE NEW PAINT JOB
- POSSIBLE NEW WHEELS
Old Sep 28, 2011 | 10:09 PM
  #6678
My_EFsedan's Avatar
sleeve'n the block is going to give you 84mm. you mean 81.5mm
Old Sep 28, 2011 | 10:54 PM
  #6679
yea i reread what i posted and it didnt sound right so i went and looked up the cp piston and its 81.5
Old Sep 29, 2011 | 07:17 AM
  #6680
stay away from blox control arms. the bushings are JUNK and WILL fall apart on you. i highly recommend you look into something better, unless you plan to put brand new bushings in as soon as you get them
Old Sep 29, 2011 | 07:34 AM
  #6681
90HondaDA's Avatar
i bought a set of BLOX LCAs and pressed out the bushings the energy ones i had wouldnt even fit in so i just bought a set of skunk2s
Old Sep 29, 2011 | 07:35 AM
  #6682
90HondaDA's Avatar
Also if you are picking between b16 and itr valve train i know that the ITR valves are forged one piece. I am running ITR valve train on a 600hp goal. with SuperTech springs and retainers
Old Sep 29, 2011 | 08:29 AM
  #6683
I had blox lca before, never had a problem but I do hear it goes bad a lot.
I had a b16 head before with type r internal and gsr cam on my b20v turbo and it was great so imma just do the same setup.
Old Sep 29, 2011 | 08:30 AM
  #6684
90HondaDA's Avatar
basically what i have on my b20v b16 with ITR valve train and skunk2 cams
Old Sep 29, 2011 | 08:39 AM
  #6685
doclara's Avatar
New the import world....traded my bike for a 93 cb7. It's a good start as it has some work done to it. But the car needs work. I'll post picks soon.
Old Sep 29, 2011 | 09:14 PM
  #6686
looking forward to it.
Old Sep 29, 2011 | 09:22 PM
  #6687
i hear people order bushings from skunk2 to put in their blox control arms. but i also coulda sworn people put es bushings in as well. but i could be wrong on that one?
you were one of the lucky ones. everyone once in a while i come across someone who actually didnt have problems, but 9 times out of 10, they destroy em in no time
Old Sep 29, 2011 | 11:36 PM
  #6688
90HondaDA's Avatar
I had a full set of energy suspension bushings and i couldn't get the LCA bushings to fit the blow
Old Sep 30, 2011 | 06:15 AM
  #6689
SLOENUF's Avatar
What do you guys think tranny wise for the ls. Go with a b16 or gsr?
Old Sep 30, 2011 | 06:58 AM
  #6690
personally, i like the gsr tranny. its shorter, but its not so short to where high way driving becomes annoying. i know a lot of people who have b16 tranny's and they hate highway driving. one option you could do is to put an ls 5th gear in it for cruising and gas saving. then you have the best of both worlds
Old Sep 30, 2011 | 07:44 AM
  #6691
90HondaDA's Avatar
i want to put a LS 5th in my turbo DA because my type-r will get garbo highway
Old Sep 30, 2011 | 08:18 AM
  #6692
I had a b16 and now have a gsr I personally like the gsr better. I daily my car and when had the b16 driving to work it was horrible and it killed my gas like crazy. B16 for track gsr for daily!!
Old Sep 30, 2011 | 08:24 AM
  #6693
DumaDA's Avatar
b16 with ls 5th ftw
Old Sep 30, 2011 | 09:15 AM
  #6694
b16 with ls 5th if you got the money and want to go that route, if you want to just drop one in with no issue then gsr! FTW.
Starting my new job monday!
Old Sep 30, 2011 | 10:00 AM
  #6695
SLOENUF's Avatar
Yea I've read that about the b16. Pretty pricey to get the ls 5th done?
Old Sep 30, 2011 | 10:07 AM
  #6696
DumaDA's Avatar
just all depends who does your work for you, if you know the right people you can probably have someone put a 5th gear in for you for a price that isnt too high, it would be the best bet for you, but it would be alot cheaper to just get a gsr transmission haha
Old Sep 30, 2011 | 11:34 AM
  #6697
My_EFsedan's Avatar
b16 with ls 5th gets my vote. my b17 gsr is worse than my b16 on the freeway haha.
Old Sep 30, 2011 | 12:33 PM
  #6698
BrayzieEF9's Avatar
My old EF lives on...
Old Sep 30, 2011 | 01:14 PM
  #6699
92Hatchzies's Avatar
New to HT but just about everything on my EG is built not bought.
Old Sep 30, 2011 | 02:08 PM
  #6700
My_EFsedan's Avatar
turbos turbos turbos damnit!
needa make money asap!
