Anyone have issues with Profec B Spec1's not holding high boost?
Just wondering if it is me, or if others have had the same problem, i have the old school Profec B Spec1 the one with the dials, not the one with the digital screen.
and at boost levels of like 20psi or more, it seems to want to fluctuate boost real bad, as if the controler cant keep up, and gate boost properly
anyone else had this issue?
this is the one i have
thnaks guys
thnaks guys
i have 9psi spring in my tial 38mm gate
im gonna turn it up abit and see what it does tomorrow, and if the timing issues may have had anything to do with it
Re: (Silverbeast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silverbeast »</TD></TR><TR><TD CLASS="quote">I would definatley take that boost controller over the Spec 2 any day. Might want to move to a 10-12psi spring and it should be fine.</TD></TR></TABLE>
I've never had any problems with the profec spec 2. I acutally like it alot better then the spec 1 but the spec 1 works fine also. Definately shouldn't be having that problem with a 9psi spring and only 20 lbs of boost. Check into ur lines and make sure everything else is up to par.
Re: (lucidvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lucidvtec »</TD></TR><TR><TD CLASS="quote">try the gain control......that can mess you real bad...
also...how do u have the vacumm lines hooked up.....
i have the gain set to full sharp
and the vacuum lines are set up just like the diagram i got from thier site, the diagram is kinda odd but i did it that way and it has worked well up until now, till i went to go above 18psi
Re: (mrbsponge)
I have the greddy profec Type-S. I guess it is a profec II but with analog ***** like the profec I. I always had issues when at just 10psi but I think that was related more to crappy internal wastegate. Hopefully on this new setup (shoping with Full-Race requires patience....) I won't have similar issues to what you are describing.
jetlude
08-01-2007 09:13 AM
turbo95eg6
06-12-2005 12:15 PM
SilverLudeSi
11-24-2002 09:42 PM
accordfreak
12-25-2001 12:20 AM
