who made there own FMIC piping??
just would like to know where u might of got it done at,,
also,,if any of u got the manderal bent pipe from jc whitney
let me know what pieces u ordered,
i will prob go the same route,,i dont really wanna spend more money then i need too,,
i would like to know exactly what i need
i just wanna get maybe 2.5 inch pipe
do u think 3 inch IC pipeing is to big??
im gonna check ans see what the inlet,,and outlet size is,,
and might try to stay the same size
i think i have 2.25 now,gotta double check
thanks mike
thanks mike
Re: who made there own FMIC piping?? (Wrath of VTEC)
how much HP do you plan on making? 3 inch is definately too big for most applications. i'd say <300 HP 2.25 300-550 or so 2.5 550+ 3"....
Re: who made there own FMIC piping?? (lazerus)
I bought a $30 aluminium ebay CAI and used my stainless steel bends from the Maxrev kit (which is incomplete). Held them together with couplings. Works well. The Maxrev piping is 2.25" going to a 70mm pipe for the CAI.
New User
i did all my piping... 2" from compressor to intercooler 2 1/4" from intercooler to TB.
But my goal is only 200 whp
Do a search for other opinions on what bends u need.
I started from scratch... no piping at all had to make it all
1 180 bend 2 1/4"
1 45 bend 2 1/4"
1 90 bend 2 1/4"
1 180 bend 2"
1 45 bend 2"
1 90 bend 2"
HTH
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazerus »</TD></TR><TR><TD CLASS="quote">how much HP do you plan on making? 3 inch is definately too big for most applications. i'd say <300 HP 2.25 300-550 or so 2.5 550+ 3"....</TD></TR></TABLE>
1 180 bend 2 1/4"
1 45 bend 2 1/4"
1 90 bend 2 1/4"
1 180 bend 2"
1 45 bend 2"
1 90 bend 2"
HTH
what he said
Re: who made there own FMIC piping?? (Civtek)
I bought 5-5 U bends and made the whole piping kit. You can make any angle with a u-bend and a protractor.
the inlet to the TB is usually 60 degrees
i used my aem cai 2.5 inch and 3 u bends 2 inch and 1 90 degree bend 2 inch. 2 inch silicone couplings and one 2inch to 2.5inch. you just need to make sure you thoroughly clean out any metal dust/shavings from cutting.
Re: who made there own FMIC piping?? (scttydb411)
if i were to go with some jc whitney pipe.would u say go with the
aluminized tubing they sell
or the
304 stainless steel tubing??
i think i can take this lil project on,,just gotta find out if im gonna do more good,,if i increse to bigger piping,,rather then hurt my perf
thanks mike
or the
thanks mike
Location: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
I have the maxrev kit, but I had to buy more piping anyway.
Out of the compressor is 2", then to intercooler piping which is 2 1/4, then to the charge pipe which is my.. was... my AEM cold air, which is 2.75 inches, so it just basically goes up as it goes to my throttle body.
You are fine with 2.25 piping of you are staying under 300whp, Worry about more important things, like 3 inch exhaust and a high flow cat or test pipe or something. That and tuning and whatnot.
Re: who made there own FMIC piping?? (SiRkid)
http://www.cse.uconn.edu/~yele....html
Go here, in the story it will tell you what pipes to get from JC Whitney and where to cut them.
I bought pipes from JC just Monday of this week and it shipped Wednesday of this week.
Total was like $70 something. Piping is 2 1/2 Outer diameter.
Re: who made there own FMIC piping?? (jz)
I have just a T3, and the outlet is 2 inches. I went from turbo to IC 2" piping, from IC to TB 2.25".
I think 2.5" all the way around is too big unless you gotz mad horsepower yo
HELLO,GOOD MORNIN'
Re: who made there own FMIC piping?? (si_mekanik)
Made my own, looks just like rev-hard. I copied, but the only difference is from turbo to intercooler it's 2in witha 2.5transition coupling, then 2.5 to TB. It should work good. My intercooler will be 18x6x3 core size. End to end 26 in.
Re: who made there own FMIC piping?? (HybridcivicLS-T)
you want ghetto IC piping??? my buddy made his out of a pool latter..... i'm not shitting you...... his name is myvtec8u on here....
Re: who made there own FMIC piping?? (2lowintegra)
I'm using JC Whitney piping (2 1/4" from my previous CAI) but I have to wonder, why not use PVC piping beside the fact that it looks ghetto. I know it holds great pressure because I have a pneumatic potato gun that I fill to 150PSI.
Boostinb20!
09-17-2008 10:16 AM
