Look what I found!
Old Jun 6, 2003 | 10:33 PM
2.2's Avatar
2.2
Default Look what I found!
I have been losing my mind over which turbo I should get for my GS-R for quite a while. I was wanting something that was cheap, reliable, quick to spool, and would give me boost up to redline (6 or 7psi max). Well, I think I may have found it.
I was looking at MHI turbos because everyone seems to think that they are pretty reliable and well made. The only problem was that no one makes a manifold with a Mitsu style flange for a B-series motor.
After much searching I found that http://www.hahnracecraft.com has a "Super" 16g that has a T3 flange and a larger exhaust housing than a Big 16g.
What does everyone think of this? I am not worried about high boost levels becuase I am not looking for serious power. Just something fun and have an easy time building a kit with. 6 to 7psi is enough for me. I also want to keep a stock block.
Kenton
Old Jun 7, 2003 | 12:43 AM
tegasaurus's Avatar
Default Re: Look what I found! (2.2)
sounds liek it'll produce some nice flat torque levels with a ahealthy amount of mid range power.
good for 300 or so i think! looks good. what else do you plan on running for your setup?
Old Jun 7, 2003 | 07:17 AM
2.2's Avatar
2.2
Default Re: Look what I found! (tegasaurus)
Here is what I plan on doing for the turbo kit:
Super 16g
DIY manifold
DIY DP
Spearco FMIC
DIY Charge Pipes
Hondata S100 w/boost
DSM Injectors
Blow-off valve (not sure what kind)
Exhuast (not sure what kind)
That is about all I can think of right now. I just woke up, so I am sure I am missing something.
Kenton
Old Jun 7, 2003 | 07:37 AM
Tinker219's Avatar
DIY, as in, you making the manifold, or someone else?
Old Jun 7, 2003 | 08:12 AM
2.2's Avatar
2.2
Default Re: Look what I found! (Tinker219)
Me and a friend making it. Although, If I could find an equal length tubular manifold that would let me keep my a/c and was priced ok, then I may get one.
Kenton
Old Jun 7, 2003 | 08:17 AM
CivicSoul's Avatar
Ha ha, you missed out! Sorry, I am just bragging. Stay tuned for tinkers sidewinder! Which by the way, I want to see!
C4lebh
Apr 23, 2014 05:56 PM
1lowek2007
Dec 5, 2012 06:53 PM
eshlil
Mar 16, 2007 03:51 PM
Chris F
Jun 4, 2005 08:17 PM
plkalra
Oct 28, 2004 05:06 AM
