What would you do? Fuel system related...
My goal is 225 hp at the wheels reliably.
I currently have a walbro intank pump running a 12:1 Vortech FMU.
For obvious reasons this setup is insufficient, even at the 5 psi that I'm running I hear an occasional ping.
I have some eclipse 440 injectors not installed.
What should I do?
They don't make a Hondata for my car
They don't make a Zdyne for my car
I don't want an AEM EMS because it is for more of a race car and mine is still a street car that will have to have it's turbo removed for smog.
Can I just run the 440's with an AFC? Should I just get an inline pump and turn up boost to 7psi?
Thanks for any help!
[Modified by FuzzyGreenCarpets, 5:45 PM 3/3/2002]
What should I do?
Re: What would you do? Fuel system related... (FuzzyGreenCarpets)
why do you think you have to remove the ems for smog? is there a visual ecu check? that's also one of the points of the ems, is the install/removal is 5 min.
[Modified by 98Psi ITR, 9:09 PM 3/3/2002]
Re: What would you do? Fuel system related... (dlplayboy)
It's pinging because he is using the Walbro and a 12:1.
Duh.
What is there to tune on a turbo kit with no fuel management system?
Duh.
Try finding a tuner who works on Haltech in your area. One should run you around $1000 and it has more tuning options than a hondata. You mentioned you would get a hondata if they made one for your car right? Well haltech is just a little better and a little more $$$
have it dynoed and see if your air fuel ratio is ok,if it is,either run better gas, octane booster or turn timing down a degree or two,if it aint,try adding an inline pump such as an MSD or Bosch unit maybe its leaning out.
Get an inline fuel pump a s-afc and a 4:1 rise rate fmu disk and put them 440cc on there and u will be ok
who told u to use a 12:1 fmu with a intank fuel pump that's just like telling u to blow your motor up and u asked why u pinging because your running lean and try to retard your timing
[Modified by DLB1994, 11:55 PM 3/4/2002]
