Fuel Help
Old Aug 28, 2002 | 08:56 PM
gsr sol's Avatar
Default Fuel Help
I really need a straight answer on this one because I am playing against the clock. I have gone through 2 holly fuel pumps in 2 days, so I am guessing something is wrong with the fuel setup. This is what I will have as of tomorrow:
B18C1 9:1 compression Drag 3 turbo kit
440cc injectors
12:1 vortech fmu
B&M fpr
hondata 3b (starter map for boost)
walbro intank fuel pump (GSS 317)
airtek inline fuel pump
I know it needs to be dyno tunned but I want to break in the internals first. So if the engine sees boost it won't be anymore than 7psi until I dyno tune it. When I went through the two Holly pumps the setup was the same except i didn't have the inline pump. Is there anything in this setup that would cause a problem with the fuel pump going out again. By the way if anyone is wondering, I didn't have to pay for the holly tanks.
Old Aug 28, 2002 | 09:00 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Fuel Help (gsr sol)
why are running a FMU with hondata?
YOu dont need an fmu or the inline pump. Just use the intank with the 440cc injectors and get it tuned. I think the fmu is messing up your pumps becuase you are running high fuel pressure due to the fmu.
art
Old Aug 28, 2002 | 09:06 PM
gsr sol's Avatar
I thought that might be the problem. I am going to have them remove it tomorrow. So the B&M should do the job with the Hondata even while boosting?
Thanks
Old Aug 28, 2002 | 09:09 PM
Arturbo's Avatar
Better than steak
25 Year Member
If Im not mistaken, sonny once said he tested the B&M and it didnt raise fuel pressure like it should have 1:1. I think he said the stock worked better, but it wasnt adjustable. Your other option is the AEM adjusable.
Sonny can you give some input on this if you read this?
art
Old Aug 28, 2002 | 09:11 PM
gsr sol's Avatar
thanks for the speedy response, you might have just saved me another fuel pump, or my sponsor anyway.
Old Aug 28, 2002 | 11:02 PM
Sonny's Avatar
Art is right. No FMU for that setup. The volume demand for fuel flowing through the injectors using 440cc injectors + a 12:1 FMU is probably killing your pumps. The GSS317 is not a very powerful pump above about 75 psi.
I've seen mixed results with stock or B&M FPR. I had one that rose under boost (about 0.7:1 rise rate) and two that did not. Either one is fine as long as your tuner knows what is going on.
Good luck.
Sonny
Old Aug 29, 2002 | 05:00 AM
gsr sol's Avatar
Default Re: Fuel Help (Sonny)
thanks guys.
Old Aug 29, 2002 | 09:18 AM
93LSivic's Avatar
How do you go about getting sponsors without knowing the first thing about your setup??? Please tell me, I could use the extra money.
elpiar
Mar 21, 2005 10:08 PM
Turbocivic94
Jun 1, 2004 03:04 PM
threatcon13
Oct 28, 2003 09:13 PM
civicdragger818
Jun 20, 2003 01:07 PM
CM-R
Jun 21, 2002 11:34 AM
