what happened to all archived sections?? oil feed question
what exact parts are needed when putting together an oil feed/return line together? and how much of SS hose do i need for my b16a2?? and where do i get good stuff for cheap??
ps.. what happened to all the archives??
Re: what happened to all archived sections?? oil feed question (queez)
u can get from a local performance store or online at like summit or something..
about 1.5 feet-2 feet of -8AN SS line and 2 straight -8an fittings is what my friend and i are using on his newly put tgether setup
u can also use 10 AN, maybe 12...then for the pan, crimp it to a piece of welded on shiftlinkage,and then up top connect to turbo with the proper fitting...other friends have run that in thei r 500+power setups, not like it matters, but its not like itll blow off. just a return line
Re: what happened to all archived sections?? oil feed question (hybridvteceg)
might help (and hope it works):
https://honda-tech.com/zerothread?id=232145
