Quick question
Old Jul 6, 2007 | 08:01 AM
vietelement's Avatar
Default Quick question
Where can i find an oil line like this one
Old Jul 6, 2007 | 08:43 AM
SuperTeg95's Avatar
Default Re: Quick question (vietelement)
Stan at fast-turbo.com(I think that the address)
Old Jul 6, 2007 | 11:18 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Quick question (SuperTeg95)
summitracing.com and make your own. -10 line, 1/2npt fittings.
Old Jul 6, 2007 | 09:33 PM
Default Re: Quick question (boostedcivicsir)
thank you guys i appreciate it. i've been leakin oil all over cuz, ive been usin a rubber hose for an oil line
but if i wanted to make my own custom fittin oil line, where can i get the oil line from without buyin it online?
Old Jul 6, 2007 | 09:49 PM
dpetro1's Avatar
if you dont want to order online. your local autozone or o'reilys should be able to get earl's or russell fittings for you. as mentioned above you will need a 1/2npt to -10AN (male), 2 -10AN hose ends, -10 stainless line, and a -10AN weld-on bung for the oil pan.
also depending on your set-up you may one to use a combination of 45* fittings with the straight hose ends. what is your setup so we can be more helpful?
Old Jul 7, 2007 | 11:35 PM
Default Re: Quick question (dpetro1)
i have a td04h greddy turbo with greddy manifold and downpipe. right now im just usin a rubber vac hose with a metal clamp. and its not doin a good job haha, cuz it cut through the rubber and now im leakin oil everywhere
Old Jul 8, 2007 | 02:02 PM
dpetro1's Avatar
well in that case you may need some different fittings. im not sure if the td04h has a 1/2" oil return, other that that you should be good to go. also you will probably need a matching return flange.
Old Jul 8, 2007 | 02:17 PM
alpha's Avatar
https://honda-tech.com/zerothread?id=1902396
jacob4lester
Feb 16, 2010 08:36 PM
PhantomX
Oct 14, 2008 08:53 PM
metal-x
Mar 10, 2003 04:36 AM
C1V1CS1
Oct 16, 2002 12:23 PM
Snafu-Si
Jul 2, 2002 07:58 AM
