Oil return line question. Help with this.
Old Jul 2, 2002 | 07:27 AM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Default Oil return line question. Help with this.
My oil return line for my turbo is a standard rubby hosey that I was told is okay but I notice that a lot of people run Stainless Steel briaded for their oil return line.
I was wondering if it is substantially better to do that or if it is just more of a "bling bling" thing with that.
I mean, I know that SS lines are better for most cases but in this case for a turbo oil, is it a DEFINITE thing to swap with or just something people get cause... it's more bling.
Old Jul 2, 2002 | 07:32 AM
len's Avatar
len
Default Re: Oil return line question. Help with this. (Snafu-Si)
The Stainless Stell Braided line is to protect the line from the downpipe and the extra heat. It gives it some strength also. A standard rubber hose or silicone hose will eventually fail.
Old Jul 2, 2002 | 07:34 AM
Snafu-Si's Avatar
Default Re: Oil return line question. Help with this. (iloveracing)
Okay, then I'm leaning towards getting a ss line for it then.
Old Jul 2, 2002 | 07:58 AM
len's Avatar
len
Get fittings for the turbo and where you tapped the oil pan too. It's just easier and looks much cleaner. Measure how much you want the line to be, as short as possible, and have it cut for you and then when you go to put it on, all you do is twist. Don't mess with doing it yourself. Unless you got steady hands and can cut the line clean.
hondatuner020
Apr 26, 2011 05:26 PM
Flexin5
Nov 7, 2006 11:41 AM
beepy
Mar 1, 2004 09:26 PM
reignofchaos
Jul 27, 2003 10:34 AM
lilxvtecxpwr
Oct 5, 2002 03:35 PM
