what do I do with the oil return lines?
Old Nov 15, 2002 | 12:16 PM
Wo-Nelly's Avatar
Default what do I do with the oil return lines?
I'm about to remove my turbo kit and I just got a few questions. What do I do with the oil lines feed and return? How would I go about capping them off? Anything else I should remember but I don't?
[Modified by GottaLude, 3:17 PM 11/15/2002]
Old Nov 15, 2002 | 01:25 PM
RAWB's Avatar
Default Re: what do I do with the oil return lines? (GottaLude)
WHere are you running your feed line from? If it's from the back of the block- just remove the T fitting and replace it with the sending unit.
Depending on how you tapped your oil pan for the return- it may be easier just to get a stock replacement pan.
Old Nov 15, 2002 | 01:34 PM
Wo-Nelly's Avatar
Default Re: what do I do with the oil return lines? (integracon)
anyway I can just cap it off?
Old Nov 15, 2002 | 01:38 PM
intekragsr's Avatar
jb weld
Old Nov 15, 2002 | 01:43 PM
InfamousRS's Avatar
Why do you want to just cap it off? Are you just temporarlly removing the kit?
Old Nov 15, 2002 | 02:04 PM
Wo-Nelly's Avatar
Default Re: what do I do with the oil return lines? (InfamousRS)
a long temperaily but temoeraily none the less
Old Nov 15, 2002 | 02:21 PM
T25 civic's Avatar
On mine, I had a flange that looked like the greddy return line welded into my pan, so I just got a rubber cap from autozone and clamped it on there real tight. It won't matter as long as you check it every week or so, and make sure it doesn't loosen itself up.
Nick
Old Nov 15, 2002 | 02:49 PM
Flamenco-T's Avatar
Default Re: what do I do with the oil return lines? (T25 civic)
you can use a -3 cap and -10 cap for the oil feed and lines, I am out of it, but I can get it for you, If you want I can send you some
Old Nov 15, 2002 | 02:59 PM
Wo-Nelly's Avatar
Default Re: what do I do with the oil return lines? (Flamenco-T)
Would be great, did you send them exhaust flanges? Could you send some of those caps as well? If not just point me to where I can get them.
Old Nov 15, 2002 | 03:30 PM
Flamenco-T's Avatar
ooh yeah, forgot about that..
I'll pick up some caps tmw and send it with the flanges
MalcolmV8
Dec 5, 2011 05:29 PM
dan89crxsi
May 31, 2007 08:00 AM
toolowsol
Feb 9, 2006 01:52 PM
torr
Apr 14, 2004 07:48 AM
racerxadam
May 22, 2002 03:20 AM
