what oil return line for moroso pan and Precision SC34 turbo?
I just ordered a moroso oil pan with the fitting for the turbo return line to replace my beat up and leaky stock oil pan. I want to order a fresh oil return setup as well to compliment the new pan. I want to make sure I order an oil return kit that has the correct fitting for the moroso oil pan, but nowhere do they say what fitting it is. Does anybody know where I can order a oil return line "kit" that has all the proper hardware to go from my Presision SC34 turbo to my moroso oil pan? Thanks
Re: what oil return line for moroso pan and Precision SC34 turbo? (toolowsol)
im pretty sure the moroso pan has a 1/2NPT fitting for the return (female i think). so you will need a 1/2NPT -> -10AN fitting to install into the pan and then the line can attach to that. the length of the line and whether or not you should use a 45 or 90 degree fitting will depend on what type of manifold you are using as well as your compressor configuration.
for example, i run a revhard mani with a sc34, i use a 1/2NPT return flange with a 1/2npt -> -10AN 45* fitting. then a 12" stainless hose with -10AN hose ends. one hose end is 45* and the other is straight. also i run my compressor on the passengers side.
pretty much this is my setup.
talk to stan, he can get you an configuration you need.
