Up the boost or tune?
Old Apr 27, 2004 | 08:14 PM
1tyme's Avatar
Default Up the boost or tune?
I currently have a sohc vtec turbo- greddy kit with intercooler boosting 10psi. My kit didn;'t come with the blue box so the only fuel management i have is inline pump and fmu. I'm running super rich, my car always backfires but my car is pretty quick. since I'm already running rich would it be wise to raise the boost alittle more, or i heard you get a lot more power from tuning. Originally i wanted hondata but there are no tuners down here so I'm thinking maybe VAFCII but i heard that advances ur timing, and i don't quit get that uberdata. Any suggestions
Old Apr 27, 2004 | 08:17 PM
Charles B.'s Avatar
Default Re: Up the boost or tune? (1tyme)
i would tune before upping the boost. with disc are you running on the fmu at 10psi? stock injectors?
Old Apr 27, 2004 | 08:18 PM
b16ahybrid's Avatar
yeah up the boost until your get the perfect 12.0:1 air/fuel ratio.
No don't actually do that.
What size injectors are you running?
10psi on a fmu...geeze
it may be rich in the mid-upper rpm but i'll bet it leans out closer to redline.
When I had a fmu my air/fuel ratio was good until boost hit then the afr went in the dirt (10.0:1 +) and then up top it would lean out a little because the fuel pressure will only go so high.
Old Apr 27, 2004 | 08:23 PM
beerbongskickass's Avatar
I would lower the boost until you get bigger injectors and better fuel management.
Old Apr 27, 2004 | 08:29 PM
Charles B.'s Avatar
Default Re: Up the boost or tune? (beerbongskickass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">I would lower the boost until you get bigger injectors and better fuel management.</TD></TR></TABLE>
yea that is what i would suggest. i say tune before increasing the boost as in getting something that is tunable (i.e. hondata/uberdata)
Old Apr 27, 2004 | 08:42 PM
MikeMAN's Avatar
hmm, take a risk and ruin your whole setup which you have invested time and $$ in? or have it tuned and running nicely?
answer seems simple to me..
now guys i have a question, im going skydiving next week and im thinking about going without a chute, what do you suggest?
mike
Old Apr 27, 2004 | 08:48 PM
5STAR3's Avatar
Default Re: Up the boost or tune? (MikeMAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeMAN &raquo;</TD></TR><TR><TD CLASS="quote">
mike</TD></TR></TABLE>
sounds good as long as you have uberdata/hondata
i read in a post somewhere on here that there is a good tuner for uberdata in HI
Old Apr 27, 2004 | 09:38 PM
MikeMAN's Avatar
Default Re: Up the boost or tune? (envision2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envision2teg &raquo;</TD></TR><TR><TD CLASS="quote">
i read in a post somewhere on here that there is a good tuner for uberdata in HI</TD></TR></TABLE>
lolol
mike
Old Apr 27, 2004 | 09:53 PM
greekspeed's Avatar
yes because fmu's tend to explode your motor instantaniously.
what kind of disk r u running on your fmu? is it adjustable? i wouldnt really go past 10psi on an fmu, but if your running to rich maybe look into geting a smaller disc for the fmu.
Old Apr 27, 2004 | 10:02 PM
93TurboSi's Avatar
Default Re: Up the boost or tune? (greekspeed)
if its stock bottom end i definatly would not raise the boost
Old Apr 27, 2004 | 10:03 PM
MikeMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greekspeed &raquo;</TD></TR><TR><TD CLASS="quote">yes because fmu's tend to explode your motor instantaniously.
says the FMU owner to defend its uselessness
nah, fmus aren't horrible..but at that PSI your talking crazy fuel pressures. Why risk it? Hell even a greddy blue box is better.
Mike
Old Apr 28, 2004 | 06:24 AM
b16ahybrid's Avatar
but if your running to rich maybe look into geting a smaller disc for the fmu.</TD></TR></TABLE>
So you correct the rich problem in one rpm range while making it too lean in another rpm range.
Old Apr 28, 2004 | 06:25 AM
MikeMAN's Avatar
Default Re: Up the boost or tune? (b16ahybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid &raquo;</TD></TR><TR><TD CLASS="quote">
So you correct the rich problem in one rpm range while making it too lean in another rpm range.</TD></TR></TABLE>
exactly, all your doing with modifying it using an FMU is moving the problem
mike
Old Apr 28, 2004 | 10:02 AM
1tyme's Avatar
are you serious there's an uberdata tuner in HI
if not wat other tuning options should i go with bigger injectors 310 maybe?
Old Apr 28, 2004 | 10:50 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeMAN &raquo;</TD></TR><TR><TD CLASS="quote">now guys i have a question, im going skydiving next week and im thinking about going without a chute, what do you suggest?
Dont be a *****.. You dont need a chute..
Old Apr 28, 2004 | 10:55 AM
5STAR3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1tyme &raquo;</TD></TR><TR><TD CLASS="quote">are you serious there's an uberdata tuner in HI
if not wat other tuning options should i go with bigger injectors 310 maybe?</TD></TR></TABLE>
yea, sorry i have no idea who. but in a recent post there was some guy talking about his set-up and he was going to have this "great tuner" in HI tune it(cause he lives there also)
thats all i know....
Old Apr 28, 2004 | 12:06 PM
MikeMAN's Avatar
Default Re: Up the boost or tune? (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">
Dont be a *****.. You dont need a chute..</TD></TR></TABLE>
lololol
mike
Old Apr 28, 2004 | 12:16 PM
Muckman's Avatar
Moderator in Chief
I say up to boost until your engine grenades.
Old Apr 28, 2004 | 12:51 PM
USDM 4G VTEC's Avatar
i am just going to say this
"if u are not tuned!!!, dont up the boost!!!"
just because it backfires doesnt nesesary means u are rich., maybe ur egt are to hot..... think about it... get it running right, then moew foward
! 1 step at a time!!!
Old Apr 28, 2004 | 03:56 PM
kun3racer's Avatar
go to ENDLESS GARAGE in Mapunapuna. i guarantee they can tune ur car.
Old Apr 28, 2004 | 03:57 PM
kun3racer's Avatar
i have a blue box for sale if u wanna buy it. just pm me and we can meet up.
primerk5
Aug 21, 2008 10:55 AM
vtec-adykt
Feb 3, 2005 03:31 PM
honkey2fly
Apr 22, 2004 11:50 AM
UnderPressure
Apr 29, 2002 08:04 PM
jmad08
Feb 22, 2002 05:03 PM
