240cc injectors ok?
Old Apr 22, 2004 | 07:53 AM
honkey2fly's Avatar
Default 240cc injectors ok?
5 psi of boost intercooled, reason i ask is because I am planning on doing a major engine management upgrade this summer but want to get her boosted now oh and this is a 14b turbo.
Old Apr 22, 2004 | 08:32 AM
GSRwBOOST's Avatar
Default Re: 240cc injectors ok? (honkey2fly)
having been turbo before.. and knowing people that are turbo.. your 240's wont hold up....
holding up.. would mean you running like 4-5psi and in reality... do honestly think we are going to believe your not gonna run more?
hahhahahahahahaahha
it's your call....
Old Apr 22, 2004 | 08:48 AM
honkey2fly's Avatar
Default Re: 240cc injectors ok? (GSRwBOOST)
I know I will run more but for now I just want it to get up and running and used to running boost so I will only be running 5 psi untill I get bigger injectors and a fuel pump.
Old Apr 22, 2004 | 08:49 AM
mamaboy's Avatar
get an fmu and an intank and you should be fine for now, but do not boost until you get at least an fmu or you will lean out
Old Apr 22, 2004 | 08:51 AM
honkey2fly's Avatar
Default Re: 240cc injectors ok? (mamaboy)
I have an SAFC already so do i really need a fmu?
Old Apr 22, 2004 | 09:03 AM
mamaboy's Avatar
yes you do. you cannot add more fuel than the injectors will allow. the afc is mainly used to trim fuel where it is needed.
Old Apr 22, 2004 | 09:13 AM
Mad Cow's Avatar
Come on, we've answered your question already and told you what you need to do. YOUR 240CC INJECTORS WILL NOT BE ENOUGH, you will be sorry if you try to use them for any period of time wether it be 2 days or 2 years. You WILL be sorry.
Your SAFC won't help, don't boost untill you have REAL engine management or you will be sorry. Don't convince yourself that you will be lucky, and/or better than the rest. Don't pretend that you won't boost much. You're going to be sorry.
Not sure why I'm even bothering to say this stuff, as it's obvious you're going to run the 240's regardless of anyones advice.
Old Apr 22, 2004 | 09:40 AM
Charles B.'s Avatar
Default Re: 240cc injectors ok? (MadCow)
i'm running 240cc with a 12:1 fmu and an msd inline pump on a gsr@6.5lbs. not that i'm really recommending it but if you just wanna get your setup started and going at 5psi i don't see what the problem would be as long as you don't mash on it all the time. i also plan to get some proper fuel management over the summer.
Old Apr 22, 2004 | 10:01 AM
honkey2fly's Avatar
Default Re: 240cc injectors ok? (CharlesInTurbocharge)
ok ok, I will wait and get the 440cc injectors and boost
Old Apr 22, 2004 | 10:47 AM
mamaboy's Avatar
dsm 450cc's + honda resistor box and clips are very very cheap....look around. make sure you clean and balance those suckers before you run them
Old Apr 22, 2004 | 10:49 AM
hulkhb's Avatar
Do it right the first time.
Old Apr 22, 2004 | 11:50 AM
GSRwBOOST's Avatar
Default Re: 240cc injectors ok? (hulkhb)
yea what he said....
you'll have the kit in and run 5psi.. and the second some punk kid pulls up next to you showing off.. you'll nail it.. the 240's will max out.. the turbo will keep going and boom...
your next post will be who does block builds and sleeves, then someone will mention JG and then the resulting thread will spiral into more problems than your broken engine...
get ALL the parts.. THEN install the turbo..
almost everyone here haslearned something the hardway... sometimes the expensive way..
we are here to save you money.... LOL
laakea
Apr 3, 2006 07:13 PM
spoon95eg
Dec 19, 2005 06:15 PM
shervin
Apr 16, 2005 07:16 PM
eMpAtHy
Feb 28, 2005 01:28 AM
SIK IN DA HED
Sep 28, 2002 12:57 PM
