Umm, im confused
Old Mar 26, 2007 | 07:32 PM
  #26
93turbo16's Avatar
Default Re: (Whiteintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Whiteintegra &raquo;</TD></TR><TR><TD CLASS="quote">can you explain to me why? Am i missing something? I though most people used step retards to begin with.</TD></TR></TABLE>
There have been some topics about ignition timing in crome, especially high cam and high rpm values being somewhat advanced compared to the tables/other systems. I have noticed it a lot more when using crome, not sure exactly why. So the best idea is to start with a conservative timing table and go from there. There is absolutely no reason to get aggressive with the ignition timing with out being on the dyno.
I honestly don't use crome very much because I have noticed this kind of thing for a rather long time actually, it is just now hitting the surface. Not saying that there is anything wrong with crome, just some of the ignition tables are in question right now. This kind of thing is also built into the stock rom, which wasn't made to be boosted, so that should be taken into concideration. That is all.
Old Mar 26, 2007 | 09:13 PM
  #27
Whiteintegra's Avatar
oh WOW...i had no clue! I heard crome was buggy, but damn! That crap could have potentially cost me my block! If this is the case and crome timing isn't pinpoint, then what are you using to measure timing? (please don't say Uber...i hate uber!)
Old Mar 26, 2007 | 09:22 PM
  #28
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Whiteintegra &raquo;</TD></TR><TR><TD CLASS="quote">oh WOW...i had no clue! I heard crome was buggy, but damn! That crap could have potentially cost me my block! If this is the case and crome timing isn't pinpoint, then what are you using to measure timing? (please don't say Uber...i hate uber!)</TD></TR></TABLE>
I personally use neptune on my cars. But I tune mostly uberdata, but crome if it is needed (ITBs, 3bar or big injectors) since it has better support for such things.
Crome is still perfectly able to tune your car, just get it on the dyno to get the timing worked out with it. Uberdata and even stock code have this timing correction in higer RPMs, but for some reason, it seems that there is just something amiss somewhere. I don't want to spread false information, so don't take it as perfect fact, just wanted to fill you in on personal preference and new findings.
Old Mar 26, 2007 | 10:03 PM
  #29
yeah..i just did some research. Crome's gearing/timing for certain ECUs are not completely accurate at higher gears. but there are ways to fix the problems though.
Old Mar 27, 2007 | 04:16 AM
  #30
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Whiteintegra &raquo;</TD></TR><TR><TD CLASS="quote">yeah..i just did some research. Crome's gearing/timing for certain ECUs are not completely accurate at higher gears. but there are ways to fix the problems though.</TD></TR></TABLE>
Na, not talking about the per gear trims. Because for a long time, when crome was supposed to edit fuel per gear, it was actually editing timing. Two different things we are talking about here.
Old Mar 27, 2007 | 07:16 AM
  #31
not2slo128's Avatar
Default Re: (93turbo16)
2 factors are most important to running low times in a turbo application:
1. Area under TQ curve.
2. Traction.
More is better.
oh yea... and ...
( and type R stickers =P )
Old Mar 27, 2007 | 08:57 AM
  #32
WickedHonda00's Avatar
Default Re: (not2slo128)
precisely my friend. This is why I believe maxing out a smaller turbo is much better than using 50-60% duty of a larger one.
Old Mar 27, 2007 | 06:49 PM
  #33
so what do you guys think about running high PSI on stock blocks?
elpiar
Sep 6, 2005 08:01 AM
the.hamburglar
Mar 25, 2005 01:48 AM
joepiscapo_83
Jan 22, 2005 08:45 AM
project dc2
Jul 16, 2003 09:02 PM
92HB_HB
May 9, 2003 09:35 AM
