oil line help!!
Old Jun 3, 2004 | 11:40 AM
Ad4mGSR's Avatar
Default oil line help!!
i have a greddy 18G turbo and need oil feed and return lines..anyone know if i need a certain line/fitting or if any will fit..after oil lines and turbo rebuild its going in, my friend said i need a banjo fitting for the turbo but ive seen other turbos with diff fittings, so im confused.
Old Jun 3, 2004 | 01:30 PM
2000GSRT's Avatar
Default Re: oil line help!! (Ad4mGSR)
not sure about the fittings, but go with a -3an stainless steel braided oil feed and a 1/2" SS braided oil return.
Try a search for the fittings, I know it's been covered....
http://www.hahnracecraft.com/h...l.htm
Old Jun 3, 2004 | 02:43 PM
FOrSfEd's Avatar
Default Re: oil line help!! (2000GSRT)
Check with Stan (Flamenco-t), I'm sure he has the fitting you need
Old Jun 4, 2004 | 12:32 AM
Flamenco-T's Avatar
This is all the oil lines that you'll ever need. It comes compelte and it uses a male to male fitting to the turbo rather than the banjo bolt.
The kit are made specifically for Greddy 18G.
The oil feed line kit,
The oil return line kit,
You do need to have a threaded oil drain flange for the oil return kit, most turbos comes with it, if not, I can supply you with an aluminum billet flange and gasket.
All for $ 119 shipped to your door. There are propably over 500 members here who have and used this kit and they all love it.
Let me know if I can help you with anything at all.
Stan
214-783-7247
pcguy760
Jul 15, 2008 07:12 PM
92gsrteg
Northeast (Sales)
Oct 12, 2005 06:36 PM
rpm9100
Jun 13, 2003 03:55 PM
