Turbo break-in
Old Apr 22, 2002 | 07:11 AM
senpai's Avatar
Default Turbo break-in
Is there a turbo break-in? This is going to be a brand new kit.
Old Apr 22, 2002 | 07:21 AM
TurboSohc's Avatar
Default Re: Turbo break-in (maztur)
Yes there is a turbo break in and in all honesty I really dont know it but what I think should happen is.
A-Dont go into boost at all for a few days let all the seals and oil and stuff all mesh together, actually take it in boost a few times
B-After each drive in car let the engine cool off 5 min but that's always needed when you own a turbo car.
Do a search
Old Apr 22, 2002 | 07:41 AM
brcivic411's Avatar
don't REALLY need to break in a turbo. just make sure you prime it with oil before you run it!!!
Old Apr 22, 2002 | 07:58 AM
TurboSedan's Avatar
New User
Default Re: Turbo break-in (brcivic411)
Yep, it has to have oil running through it before you start the engine!
Old Apr 22, 2002 | 09:25 AM
PrecisionH23a's Avatar
I asked this questions to a friend of mine that works at DRAG. He said there the drag kits (and i assume other turbo's as well) DO NOT require a break in period. It is up to you if you want to do this or not. Just thought i would share what i know. peace-
Old Apr 27, 2002 | 10:48 PM
NINJASPY's Avatar
Default Re: Turbo break-in (GudeH23a)
how do you prime the turbo?
Old Apr 27, 2002 | 11:00 PM
93LSivic's Avatar
Default Re: Turbo break-in (NINJASPY)
fill it with oil before you start the motor. You can use something like a turkey baster. What I did was cut off the bottom of an oil bottle, drill a hole in the cap and attach a hose, then slipped the hose over the turbo oil fitting. Then filled the bottle with oil and let it drain into the turbo--i also spun the blades to rotate the shaft so that the oil would fill the chamber and go down into the oil drain.
Thats about it. There isnt any kind of break in period, just fill with oil and boost til redline!
Old May 30, 2002 | 02:22 AM
integra-modder's Avatar
dont you prime the turbo by removing the spark plugs and turning over the engine a few times?
Old Jun 5, 2002 | 06:21 PM
iceburgslim's Avatar
Default Re: Turbo break-in (integra-modder)
Yes you can do it that way, it's much easier.
Old Jun 5, 2002 | 06:43 PM
AlphaKennyWun's Avatar
Default Re: Turbo break-in (iceburgslim)
ive never primed the turbo although I know its better to do (see Corky Bell)
Ive taken my turbo off and on 7-10 times and the turbo runs fine.
or Maybe im just lucky.
hbyrd8701
Jun 16, 2007 12:19 PM
ludeing1
Jan 12, 2007 05:40 PM
kj98r
May 16, 2004 03:16 PM
JV
Jan 23, 2002 01:23 PM
JM Performance
Sep 16, 2001 11:52 PM
