Tial wastegate
Old Nov 10, 2003 | 01:40 PM
swlabhot's Avatar
Default Tial wastegate
I've got the 35mm one and it comes with a metal ring insert that goes into the bottom hole (exhaust mani hole). Is this ring necessary? Can I mount it without using this ring? I could not get rid of the leak without using the gasket (I've blown 3 already ) and as the ring protrudes slightly I could not get the wastegate to sit flush onto the mani.
Old Nov 10, 2003 | 01:59 PM
PM-Performance's Avatar
Default Re: Tial wastegate (swlabhot)
dont use the gasket everyone has probs withthem.
yes you need that metalr\ ring though. when you tighten it down the ring should go flush , its on the the spring pressure pushningit out
Old Nov 10, 2003 | 02:04 PM
Johnyquest's Avatar
Default Re: Tial wastegate (itr206)
yeah. the ring def shouldn't stick out.
thelate1
Sep 22, 2007 07:03 AM
photec2
Aug 22, 2006 02:56 PM
95GSRTT
Jun 10, 2004 05:16 PM
dpreludesi
Feb 9, 2003 06:34 PM
shadowdawn
Apr 23, 2002 09:14 PM
