Tial Wastegate
Old Jun 10, 2004 | 12:07 PM
95GSRTT
Guest
Posts: n/a
Default Tial Wastegate
I just took off my wastegate and noticed that there was no gasket going from the wastegate to the exhaust manifold. I thought there was suppose to be some kind of gasket. Anyone have a picture of what it looks like? And whether Im wrong or right.
Also is there a VERY good chance its leaking if it doesnt have one, and thats causing that I cant boost over 6 psi?
Old Jun 10, 2004 | 12:35 PM
snailpoweredEK's Avatar
Default Re: Tial Wastegate (95GSRTT)
it shoulda came with a gasket in the box with the wastegate, mine did. :/
Old Jun 10, 2004 | 12:43 PM
boosted_dc2's Avatar
Default Re: Tial Wastegate (snailpoweredEK)
is it the gasket, or the sealing ring.
Landon
Old Jun 10, 2004 | 12:44 PM
95GSRTT
Guest
Posts: n/a
Default Re: Tial Wastegate (boosted_dc2)
arent they the same? not sure if it came with one b/c it came with the car
Old Jun 10, 2004 | 12:47 PM
they're different, the sealing ring is a silver ring, the gasket is in the shape of the flange.
Old Jun 10, 2004 | 01:15 PM
95GSRTT
Guest
Posts: n/a
Umm maybe both? Where does the sealing ring go? I saw a silver ring in there, but dont know if you mean a really thin one or just one that goes inside the wastegate from the bottom? I know im missing the gasket
Old Jun 10, 2004 | 03:49 PM
notoriousB's Avatar
the stock tial wastegate gaskets suck, they blow after 3k miles or so (in my experience) - you should be fine with no gasket or use a little bit of copper silicone to seal it
Old Jun 10, 2004 | 03:54 PM
95GSRTT
Guest
Posts: n/a
Default Re: Tial Wastegate (notoriousB)
went and got a gasket from my tuner. With the fire ring. Hopefully when I get a chance to put it on, it will fix some problems.
Old Jun 10, 2004 | 05:16 PM
2000GSRT's Avatar
im not running a gasket, no problems so far.
Just make sure that the surfaces are smooth
Dubs13
Jul 15, 2009 02:12 PM
Diego Boost
Mar 23, 2003 06:33 PM
not so civic
Aug 11, 2002 10:33 PM
boostedgsr
Jul 15, 2002 09:46 PM
