Question: Will a t3/t04e 60 trim ar .63/.70 be to laggy on B20
Just like the topic header says..ive been doing alot of searching with no real answer so...anyways i picked up this turbo and i was wondering will this turbo be to laggy for my b20....the turbo is a stage1 turbine...i only plan to run 10-12 pounds
to be specific the set-up is:
JDM b20b (dont know if it is different from a USDM one)
Skunk2 Intake manifold
Stage 1 Crower Cams
2.5 inch charge piping
2.5 DP with DMH performance E-cutout
CC-Fab log manifold (havent gotten it yet)
Garrett T3/To4e 60 Trim Stage one .63 turb .70 comp (from Blaast...thanks Guillaume)
Greddy Profec B Spec 2
Tial Style Wastegate (8 PSI Spring) dumping into atmo
ARC Type NS BOV
Greddy Style Intercooler (28"x6"x2.5")
ARP Headstuds
New oem headgasket
Chipped P28 on Uberdata
So yeah please let me know how well this turbo will perform on this set up....specifically spool time...i want to be full spooling by 4500rpm or less....thanks a bunch
Modified by IntegraG2 at 9:47 PM 4/9/2006
Stage 1 Crower Cams
ARC Type NS BOV
ARP Headstuds
New oem headgasket
Re: (IntegraG2)
I think you should be ok, I was running essentially the same thing(b20 head with LS block bored to 84 mm) so for all intesive purposes it was a b20, running the same turbo at 10 psi. I was hitting full boost around 3800.
^....were you running the exact same turbo
ive read somewhere that most of the to4e compressors all have relatively identical spool time...can anyone correct me????
wow thats not bad for a z6....i guess the b20 would around there or a bit earlier since it has more exhaust flow than the z6. so the turbo im gonna run probably isnt too big for my set up since alot of the singe cam guys are running to4e compressors....thanks GoKart....
Re: (EF9ZC)
The b20 is a monster in comparison to the z6, they are two complete difference things. So yes the full boost would be 5k on the z6, and 3800 on the b20.
i thought so...well i guess i got a good turbo for my motor....i got a larger one then i was supposed to get just incase i wanted to do a bottom end build.....im gonna blow this bottom end up first to see how much the shitty b20 sleeves handle...hahaha...ive got a b18 block thats waiting to be worked on....thanks everyone....more opinions are welcome....
Re: (IntegraG2)
I say get some 575cc injectors and 2.5bar with a walbro and see if you can tap 375hp on stock sleeves and shut everyone up. BTW the JDM b20b is 8.8cr and the USDM one is 9.6cr. There is believed to be a 9.2cr one floating too.... Mostly its the 8.8 jdm ones and the usdm 9.6ones. Good luck man, dont run too much timing.
Blaze
Blaze
thanks i might just go that route....might be kinda conservative since i want this thing to last somewhat.....but i might get power hungry
also people say that this turbo would be working inefficiently with my low boost range but when i look at the compressor map 10-12 pounds is still in that sweet spot of 79 percent......can anyone correct me
Re: (IntegraG2)
it'll be fine at 10-12 pounds but if thats all you will ever run out of it i would get something smaller and run more psi, you'll get a better midrnge
i do plan to turn up the boost....after i get lsd and better suspension....i just want a quick street car just for now....hopefully this turbo does just that. I guess there is only one way to find out. Gonna be throwing this in next month....thanks Soccerking3000
Re: (IntegraG2)
its gunna spool better than a b16 or a b18 because of the extra displacement i would assume you'd get 12 pounds by around 4400rpm or even sooner
