tapped oil pan question
Old Apr 3, 2011 | 08:03 AM
delslow45's Avatar
Default tapped oil pan question
my buddy gave me a tapped oil pan for my turbo d16 setup, my old one was pretty beat up
i've read a million times that the fitting is suppose to be as high up the oil pan as possible and it's suppose to stay clear of the baffle
the fitting sits exactly 2 inches from the top of the oil pan, just barely below the baffle(the fittings not visible from inside the pan)
i mocked up the oil pan and checked the dipstick and the fitting sits just barely above the full oil line
is this okay?
or am i gonna have draining problems?
Old Apr 3, 2011 | 06:31 PM
delslow45's Avatar
Default Re: tapped oil pan question
bump for some help please
Old Apr 3, 2011 | 07:01 PM
Desir Performance's Avatar
You should be fine, as long as the fitting clears the inside of the pan and you have no kinks in the return line you should be fine
Old Apr 3, 2011 | 07:14 PM
JDM B20 EH2's Avatar
I did my last one over to the left of my baffle closer to the transmission. Worked just fine. Most people go between the baffle and sealing surface.
josh0407
Aug 24, 2007 04:30 PM
fandango
Jan 20, 2005 06:20 PM
turbochic
May 6, 2003 02:15 PM
B20-T
Feb 24, 2003 10:44 PM
